ZM1.32 Fails to Upgrade from Debian 10 Repository
kinsham
Post by kinsham »
ZM v1.32 is installed on Debian 10 (Buster) and is prompting me to upgrade to 1.34. I have the repository set up correctly I think as below so would expect an automatic upgrade to occur.
"deb https://zmrepo.zoneminder.com/debian/release-1.34 buster/"
sudo apt-get update and sudo apt-get upgrade doesn't offer to update.
chrisw@homeserver:~$ sudo apt update
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://www.deb-multimedia.org buster InRelease
Hit:3 http://download.virtualbox.org/virtualbox/debian buster InRelease
Hit:6 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:7 https://packages.ntop.org/apt-stable/buster x64/ InRelease
Hit:5 https://www.bacula.org/downloads/baculum/stable/debian buster InRelease
Hit:8 https://packages.ntop.org/apt-stable/buster all/ InRelease
Ign:9 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ InRelease
Hit:10 https://repo.jellyfin.org/debian buster InRelease
Ign:11 https://download.webmin.com/download/repository sarge InRelease
>>Hit:12 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Release
Ign:4 https://attic.owncloud.org/download/rep ... /Debian_10 InRelease
Hit:14 https://download.owncloud.org/download/ ... /Debian_10 Release
Hit:15 https://download.webmin.com/download/repository sarge Release
Hit:13 https://packagecloud.io/netdata/netdata/debian buster InRelease
Hit:19 http://free.nchc.org.tw/drbl-core drbl InRelease
Hit:20 http://deb.debian.org/debian buster InRelease
Hit:21 http://deb.debian.org/debian buster-updates InRelease
Hit:22 http://deb.debian.org/debian buster-backports InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
Is there a problem with the repository?
Re: ZM1.32 Fails to Upgrade from Debian 10 Repository
What does apt-cache madison zoneminder say? It's probably an issue with how the packages are versioned.
You might be able to get away with apt-get install zoneminder=1.34.25-buster1
emos
Post by emos »
hello, I have the same problem, and if I type
I get
E: Version '1.34.25-buster1' for 'zoneminder' was not found
Help please
emos
Post by emos »
iconnor wrote: Sun Jun 06, 2021 3:58 pm What does apt-cache madison zoneminder say? It's probably an issue with how the packages are versioned.
This is the output:
$ apt-cache madison zoneminder
zoneminder | 1.34.22-buster1 | https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Packages
zoneminder | 1.34.16-buster1 | https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Packages
zoneminder | 1.34.15-buster1 | https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Packages
zoneminder | 1.34.11-buster1 | https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Packages
zoneminder | 1.34.10-buster1 | https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Packages
zoneminder | 1.34.6-buster1 | https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Packages
zoneminder | 1.34.0-buster | https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Packages
zoneminder | 1.32.3-2 | http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
It does not seem to see the newer versions...
emos
Post by emos »
hmmm I believe there is no buster arm package beyond 1.34.22...
Any suggestions on how to install 1.34.latest by building it for my pi?
emos wrote: Fri Sep 17, 2021 12:17 pm hmmm I believe there is no buster arm package beyond 1.34.22...
Well, you could install Zoneminder 1.36.x
A better option is to install Ubuntu on the Pi then install Zoneminder. Works much better. If you have a Pi4 use the 64 bit version of Ubuntu.
