I have a wroking pi with zoneminder
also working is the zmNinja (with API)
I can change the state using python to the zoneminder server
everything is working
right now I'm entering the server using NAT to port 80
just want to know how can I change the port of the zmNinja?
right now it's work on port 80 ( defulat)
and will it also change the zonemidner port?
are they both use the same port?
so if I will cahgne the port to 1234 (for example)
I will be able to enter the server using this port from the browser and zmNinja?
*** I thought it might be here
/etc/apache2/apache2.conf
*** update2***
if I change the port here:
/etc/apache2/ports.conf
Listen 80
Listen 1234
do I need to change something else?
Thanks,
