Any suggestions to, why this is happening ?Apr 27 13:09:09 zoneminder zmc_m18[819]: WAR [zmc_m18] [ImageBufferCount 375 is too small. Needs to be at least 553. Either increase it or decrease time between keyframes]
Apr 27 13:09:09 zoneminder zmpkg[3745]: INF [Sanity checking States table...]
Apr 27 13:09:09 zoneminder zmpkg[3745]: INF [Command: start]
Apr 27 13:09:09 zoneminder systemd[1]: Started Session c338 of user www-data.
Apr 27 13:09:09 zoneminder systemd[1]: session-c338.scope: Succeeded.
Apr 27 13:09:09 zoneminder systemd[1]: Started Session c339 of user www-data.
Apr 27 13:09:09 zoneminder systemd[1]: session-c339.scope: Succeeded.
Apr 27 13:09:09 zoneminder systemd[1]: zoneminder.service: Control process exited, code=exited, status=1/FAILURE
Apr 27 13:09:09 zoneminder systemd[1]: zoneminder.service: Failed with result 'exit-code'.
Apr 27 13:09:09 zoneminder systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Apr 27 13:09:20 zoneminder systemd[1]: zoneminder.service: Service RestartSec=10s expired, scheduling restart.
Apr 27 13:09:20 zoneminder systemd[1]: zoneminder.service: Scheduled restart job, restart counter is at 163.
Apr 27 13:09:20 zoneminder systemd[1]: Stopped ZoneMinder CCTV recording and surveillance system.
Apr 27 13:09:20 zoneminder systemd[1]: Starting ZoneMinder CCTV recording and surveillance system...
Apr 27 13:09:20 zoneminder zmpkg[3760]: INF [Sanity checking States table...]
Apr 27 13:09:20 zoneminder zmpkg[3760]: INF [Command: start]
Apr 27 13:09:20 zoneminder systemd[1]: Started Session c340 of user www-data.
Apr 27 13:09:20 zoneminder systemd[1]: Started Session c341 of user www-data.
Apr 27 13:09:20 zoneminder systemd[1]: session-c340.scope: Succeeded.
Apr 27 13:09:20 zoneminder systemd[1]: session-c341.scope: Succeeded.
Apr 27 13:09:20 zoneminder systemd[1]: zoneminder.service: Control process exited, code=exited, status=1/FAILURE
Apr 27 13:09:20 zoneminder systemd[1]: zoneminder.service: Failed with result 'exit-code'.
Apr 27 13:09:20 zoneminder systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Apr 27 13:09:20 zoneminder zmc_m18[819]: WAR [zmc_m18] [ImageBufferCount 375 is too small. Needs to be at least 553. Either increase it or decrease time between keyframes]
[SOLVED] zoneminder keeps restarting
Running 1.34.25, Im getting this all the time in the logs.
Re: zoneminder keeps restarting
Something is clearly wrong, since zm thinks the service is not started correctly, for which it tries to restart it over and over again.
It can be worked around, by removing the restart=always in the systemd file.
/lib/systemd/system/zoneminder.service
then
systemctl daemon-reload
Still needs to figure out, why the start/restart is not working properly.
#Restart=always
Enabled debugging..
So apperently sudo needs to be installed, so it can do its selfchecks.
fixed by installing the sudo package.
9 12:21:03 zoneminder zmpkg[29737]: DB1 [Testing "sudo -u www-data true"]
Jun 9 12:21:03 zoneminder zmpkg[29737]: DB1 [Test failed, 'No such file or directory'
Re: [SOLVED] zoneminder keeps restarting
Curious -
What OS package is that?
Its on Debian 10.
