dlandon's docker and ZMEventNotification with Google Coral Edge TPU USB Accelerator
SpikeyGG
Post by SpikeyGG »
Has anyone successfully run dlandon's ZM docker with Google Coral Edge TPU USB Accelerator? I just purchased on of these Coral units and I'm waiting for it to arrive in the mail. While I wait, I'm looking through the ZMEventNotification docs and I see that it supports the device (in 6.0.0+) via config changes but you must preinstall and configure libedgetpu library, tensorflow-lite library, and the pycoral APIs.
When reviewing the dlandon's docker instructions there aren't any definitions for this so do I need to go into the docker and install these manually? The dlandon's ZM installation appears to take similar switches as the ZMEventNotification but not explicitly the INSTALL_CORAL_EDGETPU switch. :cry:
ZMEventNotification options:
sudo INSTALL_YOLOV3=no INSTALL_YOLOV4=yes ./install.sh
sudo -H INSTALL_CORAL_EDGETPU=yes ./install.sh # and follow the prompts
dlandon's docker options
-e INSTALL_HOOK="0" \
-e INSTALL_FACE="0" \
-e INSTALL_TINY_YOLOV3="0" \
-e INSTALL_YOLOV3="0" \
-e INSTALL_TINY_YOLOV4="0" \
-e INSTALL_YOLOV4="0" \
-e MULTI_PORT_START="0" \
-e MULTI_PORT_END="0" \
SuperMaximus
Re: dlandon's docker and ZMEventNotification with Google Coral Edge TPU USB Accelerator
Post by SuperMaximus »
Author, did you find the solution?
I am using Dlandon's container too and thinking about GPU acceleration with Google Coral or Nvidia Jetson.
Before ordering need to make sure one of those is operable in Docker.
