After upgrade to v1.34.22 on Debian (via repo), in Event player, 'Gapless Events' setting play very fast, like 1000x, from selected event Backwards to beginning of time/events. I can select none or 'Single Event' for now. Then noticed that the events don't start playing and the Play arrow is grayed out and doesn't work, but clicking Fast Forward does start playing.
Mode: Replay even though set to none.
Drop down Rate: is always Stop.
Monitors have rate set.
Also red zone detect bar at bottom of picture is randomly gone.
What do you need from me?
Replay None, Mode: Replay Rate: Stop, no Play button
Re: Replay None, Mode: Replay Rate: Stop, no Play button
There will be more work done in event playing in .23.
Hi iconnor,
excellent work with zoneminder, I really appreciate it.
Problem: since a couple of updates ago, the playback has been defaulting to stop even though the misc. setting for each of my sources is set at 1x, and when gapless events is selected, it's playing a frame only and then skipping to the previous event and so it seems that its playing superfast 100x going backward in time. How can I regain the ability to play gapless events at 1x speed going forward in time?
Havn't seen that one. First thing I would try is clearing cookies.
better late than never, but that was bugging the hell out of me and clearing cookies did the trick. Previously web playback was always at 16x. Cheers!
oh and this is was on v1.36.32 (I realise this is for 1.34.x support) - so likely helpful to all users who come across this.
