Hello all
Wanted to implement a way to be notified when the camera goes down .Kindly guide how the same can be done. Did searched the forum(attached image) as it mentions that it notifies when camera is online..do let me know as I wanted notifcation when camera goes down
Any Email Notification Setting when camera goes down
- capture29597[1].png (26.53 KiB) Viewed 8541 times
Re: Any Email Notification Setting when camera goes down
personaly I wrote a script to do ping test and awk the syslog for error and run it every 20 mins.
If a ping fails or an error if found in the syslog an email is sent
eg.
You need to have email send capability already set up
the tail n -500 limits the syslog to last 500 lines about 4 mins time
eg.
#!/bin/bash
#set IP address
monitor1=192.168.1.100
#ping test
monitor1_chck=$(ping -c 1 $monitor1 | grep bytes | wc -l)
#write text depending on ping test
[ $monitor1_chck -gt 1 ] && monitor1_txt="UP" || monitor1_txt="Down"
#check syslog for errors
m1=$(tail -n 500 /var/log/syslog | sort -r | awk '/ERR \[zmc_m1\] \[Failed to prime | ERR \[zmc_m1\] \[Unable to/ {print $7; exit}')
# write txt depending of syslog check result
[ "$m1" = "[zmc_m1]" ] && m1txt="Failed" || m1txt="Working"
#make table of results
resultstable() {
echo -e " Name \t\t Capture\t IP Address\tStatus"
echo "------------------------------------------------------"
echo -e "monitor1 \t" $m1txt "\t"$parking" \t"$monitor1_txt
#do check to sent email
if
[ "$m1" = "[zmc_m1]" ] || [ $monitor1_chck -eq 1 ]
then
resultstable | mail -s "Zoneminder Monitor OR ping Failed" user@gmail.com
fi
Thanks for that, anyway through zoneminder the thing can be achieved ?tommisgr wrote: ↑Sat Sep 26, 2020 6:01 pm personaly I wrote a script to do ping test and awk the syslog for error and run it every 20 mins.
eg.You need to have email send capability already set upCode: Select all
#!/bin/bash #set IP address monitor1=192.168.1.100 #ping test monitor1_chck=$(ping -c 1 $monitor1 | grep bytes | wc -l) #write text depending on ping test [ $monitor1_chck -gt 1 ] && monitor1_txt="UP" || monitor1_txt="Down" #check syslog for errors m1=$(tail -n 500 /var/log/syslog | sort -r | awk '/ERR \[zmc_m1\] \[Failed to prime | ERR \[zmc_m1\] \[Unable to/ {print $7; exit}') # write txt depending of syslog check result [ "$m1" = "[zmc_m1]" ] && m1txt="Failed" || m1txt="Working" #make table of results resultstable() { echo -e " Name \t\t Capture\t IP Address\tStatus" echo "------------------------------------------------------" echo -e "monitor1 \t" $m1txt "\t"$parking" \t"$monitor1_txt } #do check to sent email m1=$(tail -n 500 /var/log/syslog | sort -r | awk '/ERR \[zmc_m1\] \[Failed to prime | ERR \[zmc_m1\] \[Unable to/ {print $7; exit}') if [ "$m1" = "[zmc_m1]" ] || [ $monitor1_chck -eq 1 ] then resultstable | mail -s "Zoneminder Monitor OR ping Failed" user@gmail.com fi
Couldnt find a filter for that so I wrote the script.
Was planing on auto setting monitor to none but http call dont work and hadnt had time to look into the API calls
I did it with a custom config file for rsyslog and a cron script:
01-custom.conf on /etc/rsyslog.d/01-custom-conf
/etc/crontab
/scripts/check-segnale-telecamere.sh
if $msg contains "Shared data not" then /var/log/zm/lost-signal.log
if $msg contains "Unable to open input" then /var/log/zm/lost-signal.log
*/2 * * * * root /scripts/check-segnale-telecamere.sh >/dev/null 2>&1
#!/bin/bash
DATA=`date`
FILE=/var/log/zm/lost-signal.log
if [ -f $FILE ]; then
PiazzaleGiardino=`grep 'PiazzaleGiardino\|zmc_m1]' $FILE | wc -l`
CancelloFabbrica=`grep 'CancelloFabbrica\|zmc_m2]' $FILE | wc -l`
Capanna=`grep 'Capanna\|zmc_m3]' $FILE | wc -l`
GarageStanza=`grep 'GarageStanza\|zmc_m4]' $FILE | wc -l`
GarageMacchina=`grep 'GarageMacchina\|zmc_m5]' $FILE | wc -l`
InternoFabbrica=`grep 'InternoFabbrica\|zmc_m6]' $FILE | wc -l`
PiazzaleFabbrica=`grep 'PiazzaleFabbrica\|zmc_m7]' $FILE | wc -l`
VialeSilvia=`grep 'VialeSilvia\|zmc_m8]' $FILE | wc -l`
if [[ $PiazzaleGiardino > "1" ]];
then
mail -s "PiazzaleGiardino ha perso il segnale." "xxxx@gmail.com" < /dev/null
echo "$DATA "PiazzaleGiardino ha perso il segnale. >> /var/log/zm/storico-disconnessioni.log
else
echo "Non ci sono state perdite di segnale dalla telecamera PiazzaleGiardino."
fi
if [[ $PiazzaleFabbrica > "1" ]];
then
mail -s "PiazzaleFabbrica ha perso il segnale." "xxxx@gmail.com" < /dev/null
echo "$DATA "PiazzaleFabbrica ha perso il segnale. >> /var/log/zm/storico-disconnessioni.log
else
echo "Non ci sono state perdite di segnale dalla telecamera PiazzaleFabbrica."
fi
if [[ $CancelloFabbrica > "1" ]];
then
mail -s "CancelloFabbrica ha perso il segnale." "xxxx@gmail.com" < /dev/null
echo "$DATA "CancelloFabbrica ha perso il segnale. >> /var/log/zm/storico-disconnessioni.log
else
echo "Non ci sono state perdite di segnale dalla telecamera CancelloFabbrica."
fi
if [[ $Capanna > "1" ]];
then
mail -s "Capanna ha perso il segnale." "xxxx@gmail.com" < /dev/null
echo "$DATA "Capanna ha perso il segnale. >> /var/log/zm/storico-disconnessioni.log
else
echo "Non ci sono state perdite di segnale dalla telecamera Capanna."
fi
if [[ $GarageStanza > "1" ]];
then
mail -s "GarageStanza ha perso il segnale." "xxxx@gmail.com" < /dev/null
echo "$DATA "GarageStanza ha perso il segnale. >> /var/log/zm/storico-disconnessioni.log
else
echo "Non ci sono state perdite di segnale dalla telecamera GarageStanza."
fi
if [[ $GarageMacchina > "1" ]];
then
mail -s "GarageMacchina ha perso il segnale." "xxxx@gmail.com" < /dev/null
echo "$DATA "GarageMacchina ha perso il segnale. >> /var/log/zm/storico-disconnessioni.log
else
echo "Non ci sono state perdite di segnale dalla telecamera GarageMacchina."
fi
if [[ $InternoFabbrica > "1" ]];
then
mail -s "InternoFabbrica ha perso il segnale." "xxxx@gmail.com" < /dev/null
echo "$DATA "InternoFabbrica ha perso il segnale. >> /var/log/zm/storico-disconnessioni.log
else
echo "Non ci sono state perdite di segnale dalla telecamera Internofabbrica."
fi
if [[ $VialeSilvia > "1" ]];
then
mail -s "VialeSilvia ha perso il segnale." "xxxx@gmail.com" < /dev/null
else
echo "Non ci sono state perdite di segnale dalla telecamera VialeSilvia."
fi
else
echo "Non ho rilevato perdite di segnale."
fi
echo "" > /var/log/zm/lost-signal.log
chmod 0777 /var/log/zm/lost-signal.log
Production: zm 1.34.26 - Debian 11 | Test: zm 1.36.33 - Debian 12
