Neolink working with ZoneMinder
Bodyguard
Post by Bodyguard »
Have anyone played with Neolink (https://github.com/thirtythreeforty/neolink) and got it working in ZoneMinder? I have tried everything I can think of under the Add Camera section. I can connect to the stream without issues from VLC. Any help would be appreciated.
Re: Neolink working with ZoneMinder
Wow Neolink looks cool!
I'm sure it's a simple thing. If vlc works, ZM should too.
Start with ffmpeg monitor type, stick the same url as you used for vlc into the Path under source tab. Make sure you set the width & height correctly.
After that we need to see logs. The information as to WHY it isn't working is there. You can turn on debugging under Options->logging to see more info.
Bodyguard
Post by Bodyguard »
Thank you! I will try that and see what I can find.
Bodyguard
Post by Bodyguard »
And as always when you ask for help it works. I appreciated your help and feedback!
