Single stream without authentication
cortnaab
Post by cortnaab » Wed Jul 15, 2020 6:19 pm
I would like to be able to stream one single monitor (5) without authentication but have the rest require authentication. Unfortunately, the app for my fish tank doesn't work the minute I turn authentication on. Does anyone know how I can do this?
Right now the stream works fine if I have Auth_Relay set to none and set my user in the GET request but not my PASS. The minute I try to add my PASS it fails no matter what Auth_Relay is set to.
burger
Re: Single stream without authentication
Post by burger » Thu Jul 23, 2020 4:32 pm
If it's only one camera, setup a 2nd VM or RPI for ZM.
Ugly, but easier than mucking around in the code or apache permissions.
fastest way to test streams:
ffmpeg -i rtsp://<ipaddress>:554/path output.mp4
from terminal, and run through paths on ispydb or in zm hcl
If you are new to cctv, read this:
