after a long time of problems and a lot of help with people this is the system I have
using pi3 B v1.3
version is v1.34.10.
the image that is running on the pi is :
from here :2020-02-13-raspbian-buster-zoneminder-1.34-0.1.img.bz2
https://zmrepo.zoneminder.com/
just enter my usb camera
with this setting
General:
Server None
Source Type Local
Function Modect
Enabled V
Linked Monitors (?) Select Some Options
Groups Select Some Options
Analysis FPS 15.00
Maximum FPS 15.00
Source:
Device Path /dev/video0
Capture Method Video For Linux version 2
Device Channel 0
Device Format PAL
Capture Palette Auto
Multi Buffering Use Config Value
Captures Per Frame 1
Target colorspace 32 bit colour
Capture Resolution (pixels) 352 288 Custom
Buffers:
Image Buffer Size (frames) 50
when there is movment , he save an event .
but when I try to watch the video - the video is not playing\palying slow\jump to end
so I thought maybe the problem is in the chrome player
try to watch it in explorer - same problem
I have download it to my computer as AVI\MPEG - get the same resualt, video is not playing\palying slow\jump to end.
when I look at the size it's about 3MB length of the movie is 20 seconds
so he is doing something ...
I ahve notice now that if I wantch live video and the alarm goes on (motion detection ) - the live video get stuck and freeze until the alarm go off.
when I look at the logs I don't see any ERR in the times of the events (or al all - which is good,no ? )
this is the image that should work from zonminder website
what could be the problem ?
Thanks ,
