Since 1.34.11, APIs have not worked
magarity
Post by magarity »
On 1.34.6 the APIs worked just fine for zmNinja but after updating to 1.34.11 they stopped working. I've updated to the latest 1.34.16 that's available for RPi but it is still failing. zmNinja says authentication succeeded but API failed. :( Is this a known problem for anyone else? (yes, I have done "Clear API cache" on zmNinja and restarted it, no luck.)
zmc
Re: Since 1.34.11, APIs have not worked
Post by zmc »
API works with OPT_USE_LEGACY_API_AUTH enabled and using &stateful=1 on 1.34.15 - didn't try without stateful connection. I don't know what zmNinja uses, but maybe ask the developer for support? If you suspect something is not right with your ZM, you can test drive the API yourself with the instructions here: https://zoneminder.readthedocs.io/en/stable/api.html
