I run ZM on Ubuntu 20.04 LTS and cannot get video stream on zmNinja (Android and desktop).
zmNinja shows correct numbers of monitors and descriptions but no video.
API and cgi-bin seems to be correct - getting url from console shows stream in web browser...
Any advices?
Problem with video stream on zmNinja
Re: Problem with video stream on zmNinja
Should be enough here to help guide you:
https://zmninja.readthedocs.io/en/lates ... s/FAQ.html
Sometimes one really has to dig into all the various log files in order to figure out where an issue is really originating.
In addition to the FAQs mentionned by SkippyDo, also make sure that you have the same timezone set accross apache's php and mysql/mariadb. I just had to do a reinstall and that created all sort of issues, including broken streams in zmNinja.
Thank you.
I had more issues than I initially thought (different timezones on db/php, login issues).
Finally get the app to work.
