Page 1 of 1
Wyze Cam not recording correct length segment
Posted: Thu Feb 13, 2020 3:32 pm
by Atoman03
Hello, I am new to this and I have installed version 1.34.2 on Ubuntu Desktop 18.04.
I am just messing around a little with adding a Wyze Cam with the beta firmware of RTSP, but when I use H264 Passthrough to record audio 24/7. It doesn't record the correct length of segments. I am not sure why it doesn't work. Please help!
Re: Wyze Cam not recording correct length segment
Posted: Thu Feb 13, 2020 10:25 pm
by iconnor
What is the correct length? Are the resulting files playable? How about turning on debug and checking the logs?
Posted: Thu Feb 13, 2020 10:36 pm
by Atoman03
The correct length is 10 minutes and the files that are made are playable. I will have to figure out how to turn on debugging and where to get the logs.
Posted: Thu Feb 13, 2020 11:49 pm
by iconnor
So there is a setting under Options -> Config... EVENT_CLOSE_MODE... if it is something other than time you can get shorter events
Posted: Fri Feb 14, 2020 12:23 am
by Atoman03
Ok, it is set to idle but the logs are saying multiple things like:
Got empty memory map file size 0, is the zmc process for this monitor running?
and
'zma -m 2' exited abnormally, exit status 255
Posted: Fri Feb 14, 2020 1:20 am
by Atoman03
After I set the EVENT_CLOSE_MODE to time it is working for now.
Posted: Fri Feb 14, 2020 2:57 pm
by Atoman03
It was working all night until this morning and it gives me these errors in the log:
Can't find process with command of 'zma -m 2'
Last analyse time for 2 Monitor-2 was zero.
Restarting capture daemon for Monitor-2, time since last capture 53 seconds (1581692146-1581692093)
And a couple times before the errors it would make a 5 minute video and then a 15 minute but it should be 10 minutes. This doesn't matter as much as the 1 minute videos though.
2020-02-14 08:59:41.753619 zmc_m2[8713].INF-zm_ffmpeg.cpp/70 [Queue input is backward in time]
2020-02-14 08:59:41.613050 zmc_m2[8713].INF-zm_ffmpeg_camera.cpp/889 [Event video offset is -0.131 sec (<0 means video starts early)]
2020-02-14 08:59:41.551377 zmc_m2[8713].INF-zm_videostore.cpp/62 [Opening video storage stream /var/cache/zoneminder/events/2/2020-02-14/770/770-video.mp4 format: mp4]
2020-02-14 08:59:41.537961 zma_m2[8716].INF-zm_monitor.cpp/1522 [Monitor-2: 001 - Opening new event 770, section start]
2020-02-14 08:59:41.316740 zma_m2[8716].INF-zma.cpp/136 [In mode 4/1, warming up]
2020-02-14 08:59:41.310868 zmc_m2[8713].INF-zm_monitor.cpp/2546 [Monitor-2: images:1 - Capturing at 0.50 fps, capturing bandwidth 45045bytes/sec]
2020-02-14 08:59:41.253074 zmc_m2[8713].WAR-zm_ffmpeg_camera.cpp/658 [Monitor dimensions are 640x480 but camera is sending 1920x1080]
2020-02-14 08:59:39.313713 zmc_m2[8713].INF-zm_ffmpeg_camera.cpp/201 [Priming capture from rtsp://admin:password@192.168.1.8/live]
2020-02-14 08:59:39.244781 zmc_m2[8713].INF-zmc.cpp/223 [Starting Capture version 1.34.2]
2020-02-14 08:59:39.227220 zmdc[8716].INF-zmdc.pl ['zma -m 2' started at 20/02/14 08:59:39]
2020-02-14 08:59:39.227210 zmdc[1107].INF-zmdc.pl ['zma -m 2' starting at 20/02/14 08:59:39, pid = 8716]
2020-02-14 08:59:39.194427 zmc_m2[8713].INF-zm_ffmpeg.cpp/82 [Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options]
2020-02-14 08:59:39.077660 zmdc[8713].INF-zmdc.pl ['zmc -m 2' started at 20/02/14 08:59:39]
2020-02-14 08:59:39.077660 zmdc[1107].INF-zmdc.pl ['zmc -m 2' starting at 20/02/14 08:59:39, pid = 8713]
2020-02-14 08:59:39.038880 zmdc[1107].INF-zmdc.pl [Command 'zmc -m 2' removed from pending list at 20/02/14 08:59:39]
2020-02-14 08:59:38.978620 zmdc[1107].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2020-02-14 08:59:38.941750 zmdc[1107].INF-zmdc.pl ['zma -m 2' sending stop to pid 8708 at 20/02/14 08:59:38]
2020-02-14 08:59:38.849290 zmwatch[1321].WAR-zmwatch.pl [Restarting capture daemon for Monitor-2, no image since startup. Startup time was 0 - now 1581692378 > 45]
2020-02-14 08:59:28.806670 zmwatch[1321].WAR-zmwatch.pl [no memkey in zmMemInvalidate]
2020-02-14 08:59:28.764640 zmdc[8708].INF-zmdc.pl ['zma -m 2' started at 20/02/14 08:59:28]
2020-02-14 08:59:28.764640 zmdc[1107].INF-zmdc.pl ['zma -m 2' starting at 20/02/14 08:59:28, pid = 8708]
2020-02-14 08:59:28.692550 zmdc[1107].INF-zmdc.pl ['zmc -m 2' exited, signal 14]
2020-02-14 08:59:28.678087 zmc_m2[8701].INF-zmc.cpp/223 [Starting Capture version 1.34.2]
2020-02-14 08:59:28.517790 zmdc[1107].INF-zmdc.pl ['zmc -m 2' sending stop to pid 8701 at 20/02/14 08:59:28]
2020-02-14 08:59:28.246169 zmc_m2[8701].INF-zm_ffmpeg.cpp/82 [Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options]
2020-02-14 08:59:28.198650 zmdc[1107].WAR-zmdc.pl [Can't find process with command of 'zma -m 2']
2020-02-14 08:59:28.099930 zmdc[8701].INF-zmdc.pl ['zmc -m 2' started at 20/02/14 08:59:28]
2020-02-14 08:59:28.099910 zmdc[1107].INF-zmdc.pl ['zmc -m 2' starting at 20/02/14 08:59:28, pid = 8701]
2020-02-14 08:59:28.053810 zmwatch[1321].INF-zmwatch.pl [Restarting capture daemon for Monitor-2, shared data not valid]
2020-02-14 08:59:28.030910 zmdc[1107].INF-zmdc.pl [Starting pending process, zmc -m 2]
2020-02-14 08:59:28.008390 zmwatch[1321].ERR-zmwatch.pl [Memory map file '/dev/shm/zm.mmap.2' does not exist. zmc might not be running.]
2020-02-14 08:59:19.124350 zmdc[1107].INF-zmdc.pl ['zma -m 2' exited normally]
2020-02-14 08:59:18.079060 zmdc[1107].INF-zmdc.pl ['zmc -m 2' exited normally]
2020-02-14 08:59:17.970043 zmc_m2[8661].INF-zm_ffmpeg.cpp/70 [Queue input is backward in time]
2020-02-14 08:59:17.953980 zmdc[1107].INF-zmdc.pl ['zma -m 2' already running at 20/02/14 08:55:57, pid = 8664]
2020-02-14 08:59:17.918580 zma_m2[8664].INF-zm_event.cpp/588 [Updating frames delta by -0.23 sec to match video file]
2020-02-14 08:59:17.890541 zmc_m2[8661].WAR-zm_ffmpeg.cpp/70 [error while decoding MB 92 50, bytestream -9]
2020-02-14 08:59:17.844860 zmdc[1107].INF-zmdc.pl ['zmc -m 2' sending stop to pid 8661 at 20/02/14 08:59:17]
2020-02-14 08:59:17.779560 zma_m2[8664].INF-zm_monitor.cpp/686 [Monitor-2: image_count:2054 - Closing event 769, shutting down]
2020-02-14 08:59:17.735740 zmdc[1107].INF-zmdc.pl ['zma -m 2' sending stop to pid 8664 at 20/02/14 08:59:17]
2020-02-14 08:59:17.570830 zmwatch[1321].WAR-zmwatch.pl [Restarting capture daemon for Monitor-2, time since last capture 50 seconds (1581692357-1581692307)]
2020-02-14 08:58:27.432611 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:2100 - Capturing at 14.29 fps, capturing bandwidth 204256bytes/sec]
2020-02-14 08:58:23.544965 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 2000 - Analysing at 14.29 fps]
2020-02-14 08:58:20.182145 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:2000 - Capturing at 12.50 fps, capturing bandwidth 189750bytes/sec]
2020-02-14 08:58:16.368682 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 1900 - Analysing at 14.29 fps]
2020-02-14 08:58:12.889460 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:1900 - Capturing at 14.29 fps, capturing bandwidth 210752bytes/sec]
2020-02-14 08:58:09.174552 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 1800 - Analysing at 12.50 fps]
2020-02-14 08:58:05.864189 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:1800 - Capturing at 14.29 fps, capturing bandwidth 202306bytes/sec]
2020-02-14 08:58:01.684247 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 1700 - Analysing at 14.29 fps]
Posted: Wed Feb 19, 2020 2:49 am
by Atoman03
I haven't figure anything else out yet.
Posted: Fri Apr 17, 2020 10:55 am
by stevie187
Did you ever get to the bottom of this I'm having a similar problem with a NEOS camera (which I believe is the same hardware) with DAFANG firmware.
Posted: Sun Jan 17, 2021 2:13 pm
by dzogurt
I have exactly same issue. Had you have chance to solve it and get 10min video events?
I my case I get 0:10-1:00min long events...
