Possibly to automatically merge alarms close together in time without extending a single alarm?
Posted: Thu Feb 13, 2020 8:10 am
Been using ZoneMinder for a little while now (couple of months) and it's really great! Quite often I'll get two alarms quite close together (within one minute maybe) where someone goes past a camera, then comes back shortly afterwards. Ideally I'd like to get one event, where the alarms are close enough together in time, rather than two.
I found a setting that extends an alarm which I think would mean they'd get merged if the second one did occur within that time-frame, however this also means that the duration of all my individual alarms are extended out as well. Is it possible to be able to merge alarms together without the initial one being extended where there isn't a second one?
