Page 1 of 1
Events last hour blank
Posted: Thu Nov 21, 2019 9:20 pm
by geraldbrandt
If the main page shows event happening in the last hour, clicking on the number shows 0 Events. If I click on the Day column, it shows me the day, and includes the events in the last hour.
I just did an upgrade from 1.33.10 (I think) to 1.33.14.
Gerald
Re: Events last hour blank
Posted: Mon Dec 02, 2019 6:48 pm
by geraldbrandt
Is anyone seeing the same issue, or is it me?
Gerald
Posted: Mon Dec 02, 2019 8:02 pm
by iconnor
This would indicate that your event counts tables are out of sync.
You can try running zmaudit.pl to update them.
Posted: Mon Dec 02, 2019 9:18 pm
by geraldbrandt
zmaudit.pl -c was already running. I killed it and ran zmaudit.pl from the command line.
I got a few of these: Deleted 10 log table entries by time
but not much else. Clicking on Last Hour Events still brings up a page with no events listed.
Gerald
Posted: Mon Dec 02, 2019 10:46 pm
by iconnor
Now I am suspecting a timezone problem. Aren't you gett lots of errors in logs about invalid timezone?
We moved the timezone setting from php.ini to Options -> System -> Timezone
Posted: Tue Feb 18, 2020 2:36 am
by mtader
It was a timezone issue for me. I needed to go into Options -> System -> Timezone and update to my timezone and the events appeared. THANKS!
