Hi , i've problem with parameters with "Execute command on all matches".
My script send a notification with Pushover. But i want send the image with the highest score.
I use %EPIM% (Path to the (first) event image with the highest score) but the result is "?view=frame".
The problem is same with %EP% Path to the event, %EPS% Path to the event stream, %EPI% Path to the event images, %EPI1% Path to the first alarmed event image.
Have you un solution ?
PS: parameters are here https://zoneminder.readthedocs.io/en/st ... vents.html
Thanks you
filter Events parameters not working
Re: filter Events parameters not working
You have to put quotes around them. The url's contain & which has meaning to the shell. So use "%EPS%"
