Proxypass and api
fennec
Proxypass and api
Post by fennec »
Hi
I manage 3 servers zoneminder, i use another server with openvpn to 3 servers
I use letsencrypt for https on server and after proxy pass to other server
I can't have api ....
On local server zoneminder is ok like http://iplocal/zm
This is my apache config for one server
For each server i have different port
<VirtualHost *:448>
        ServerName zon.ddns.net
        SSLEngine On
        SSLProxyEngine On
        SSLCertificateFile      /etc/letsencrypt/live/zon.ddns.net-0001/fullchain.pem
        SSLCertificateKeyFile   /etc/letsencrypt/live/zon.ddns.net-0001/privkey.pem
        ProxyRequests Off
        ProxyPreserveHost On
        ProxyVia On
        <Proxy *>
                Require all granted
        </Proxy>
        ProxyPass /zm http://11.0.0.186/zm/
        ProxyPassReverse /zm http://11.0.0.186/zm/
        ProxyPass /cgi-bin http://11.0.0.186/cgi-bin
        ProxyPassReverse /cgi-bin http://11.0.0.186/cgi-bin
        RequestHeader set X-Forwarded-Proto "https"
        RequestHeader set X-Forwarded-Port "448"
</VirtualHost>
I can view live but not video replay and no access api
Missing Controller
Error: Controller could not be found.
Error: Create the class Controller below in file: app/Controller/Controller.php
<?php
class Controller extends AppController {
Notice: If you want to customize this error message, create app/View/Errors/missing_controller.ctp
Stack Trace
Do you have a idea ?
Thanks a lot
Re: Proxypass and api
I use that setup myself and it works fine.
There is something wrong with your config. Let's see your apache configs on the backend devices.
fennec
Post by fennec »
iconnor wrote: Wed Aug 28, 2019 1:33 pm I use that setup myself and it works fine.
Thanks a lot for your help
this my conf on one server
fennec@Serveur_Ubuntu:/etc/apache2/conf-available$ cat zoneminder.conf
AllowOverride All
Require all granted
</Directory>
Alias /zm/cache /var/cache/zoneminder/cache
<Directory /var/cache/zoneminder/cache>
AllowOverride None
<IfModule mod_authz_core.c>
# Apache 2.4
Require all granted
</IfModule>
<IfModule !mod_authz_core.c>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
RewriteEngine on
RewriteBase /zm/api
</Directory>
RewriteEngine on
RewriteRule ^$ webroot/ [L]
RewriteBase /zm/api
</Directory>
RewriteEngine On
RewriteRule ^ index.php [L]
RewriteBase /zm/api
</Directory>
fennec
Post by fennec »
i add this and now api is ok
ProxyPass /zm/api http://11.0.0.186/zm/api
ProxyPassReverse /zm/api http://11.0.0.186/zm/api
ProxyPass /api http://11.0.0.186/zm/api
ProxyPassReverse /api http://11.0.0.186/zm/api
but on ZMninja no error when i logging
but no image on live on all monitor
AM DEBUG Image load error for monitor: 12 sceduling for connkey regen in 2s
