I am noticing that under the playback progress indicators some monitors aren't showing which frames in the stream the alarm occurred on. Others work.
I am running 1.33.14 from the PPA. Just noticed this over the last couple of days.. Any pointers as to where to look?
Events stop showing red alarm frame indicators [SOLVED]
Re: Events stop showing red alarm frame indicators
figured this out.
Looks like when using storage areas that on NFS share, and if the share is mounted with "sync" zoneminder doesn't like it. It needs to shares to be mounted "async" via NFS. maybe a candidate to add the wiki or manual.
