Im searching for some log cohered to user and admin logging in atempts. I would like to see when some user try to log in to console and when his session ends.
Also it is possible to view some timeline when users and admins log in to view cameras?
Regards,
Mark.
View user logging atempts
Re: View user logging atempts
When a user logs in, a log entry is created at the INF level. So if you are storing INF level logs to the database, then you click on Log and filter for INF level events and see them.
When someone logs out, a similar INF level log entry is stored. A person does not have to logout though. They might simply close their browser, so it can be difficult to ascertain when they stopped using ZM.
The UI is not great for searching specifically for these types of events.
The timeline that you are interested in does not exist and no one is funding anyone to build it at this time.
Thank you for your reply.
Is it possible some easy way to export exac logs (which once?) for examle to excel, sort them and than find data?
I dont know where to look at logs, plenty and plenty trash around...
