Zoneminder 1.33.X Debian 9
dabeast1973
Post by dabeast1973 » Sun Jun 09, 2019 1:27 pm
I currently have Zoneminder 1.30.4 installed on Debian 9 and was wondering what the easiest path would be in upgrading it to 1.33.X? I looked at Zoneminder Repo but you all seem to only support Fedora and Centos builds. Will you eventually add Debian to the mix? Thanks in advanced
Re: Zoneminder 1.33.X Debian 9
Post by rockedge » Sun Jun 09, 2019 8:31 pm
I think there is a Debian package that is maintained. There is more info about it in this forum. I'll see if I can find more out and I'll post what I find
Post by bbunge » Tue Jun 11, 2019 3:12 pm
pgrunwald
Post by pgrunwald » Tue Jun 11, 2019 4:02 pm
How would this work for an existing 1.30.4 installation running MariaDB? Does it upgrade automatically if I add the repository?
I have sudo.
I have Apache running and configured.
I have MariaDB running.
PHP is configured.
Zoneminder service is enabled.
Can I just?:
sudo nano /etc/apt/sources.list
adding
# ZoneMinder repository
deb https://zmrepo.zoneminder.com/debian/release stretch/
sudo apt install apt-transport-https
wget -O - https://zmrepo.zoneminder.com/debian/archive-keyring.gpg | sudo apt-key add -
sudo apt update
sudo apt install zoneminder
Post by iconnor » Tue Jun 11, 2019 9:17 pm
you may have to remove the installed zoneminder and then install the new one from zmrepo. We use a different versioning convention. I might be wrong though.
I havn't built a package for debian recently, but will do so now.
pgrunwald
Post by pgrunwald » Tue Jun 11, 2019 9:20 pm
Thanks, I'm trying to avoid a complete reconfiguration.
Post by iconnor » Tue Jun 11, 2019 9:31 pm
You should be fine, just be ware that your apache config will need a new line or two.
pgrunwald
Post by pgrunwald » Tue Jun 11, 2019 9:35 pm
Should I wait for the results of your build?
Post by bbunge » Wed Jun 12, 2019 11:56 pm
As a test I fired up a Debian 9 machine, updated it, installed Apache, Mariadb and PHP.
Added source:
Except for the Zoneminder source I followed the install instructions at: https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way
Ended up with an operating Zoneminder 1.32.3 on my Pi 3 B+
Switching to the above source you should be able to upgrade with no issues.
pgrunwald
Post by pgrunwald » Thu Jun 13, 2019 7:51 pm
pgrunwald
Post by pgrunwald » Fri Jun 14, 2019 4:49 pm
Thank you for a near painless upgrade.
I did need to change all my cameras (4 reolink, 1 wansview) from remote to FFMPEG but that is what I was planning on doing anyway. System is stable, load is about the same, and I'm not getting errors from the RSTP wifi cameras the way I used to.
All I did was add the repository, get the key, and "sudo apt update" then "sudo apt upgrade".
Once again, I appreciate the effort and support of the developers. Thank you!
-Paul
dabeast1973
Post by dabeast1973 » Sat Jun 15, 2019 1:11 am
I essentially did what bbunge did to upgrade from 1.30.4 to 1.32.3.on two separate systems running 8+ cctv cameras each. So far so good. Thanks for all the advice.
