Update to 1.33.9
gsaindon
Update to 1.33.9
Post by gsaindon » Fri May 17, 2019 4:09 pm
I get this error updating to 1.33.9
The following packages have unmet dependencies:
zoneminder : Depends: libssl but it is not installable
Recommends: zoneminder-doc (>= 1.33.9~20190517112457-xenial) but 1.33.8~20190506105058-xenial is to be installed
E: Unable to correct problems, you have held broken packages.
Thanks,
DVB Hardware
Re: Update to 1.33.9
Post by DVB Hardware » Sat May 18, 2019 5:09 pm
I cannot upgrade 1.33.8 on Linux mint 19.1 via ppa or terminal it is like 1.33.9 does not exist
Jimmy
Linux Mint 20.04 Cinnamon Mariadb using Master
Post by rockedge » Sat May 18, 2019 6:05 pm
I think v 1.33.8 is the zoneminder-master and v 1.33.9 is zoneminder-storageareas. It appears that the work on storageareas which iconner does the main experimentation and development on before it is pushed to the master branch, is not quite ready to be integrated into the master.
try using
sudo add-apt-repository ppa:iconnor/zoneminder-storageareas
sudo apt-get updat
e
DVB Hardware
Post by DVB Hardware » Sat May 18, 2019 9:30 pm
That is what I have been using for a long time, always updating on each new release
Always the master updates before storageareas...not this time
https://launchpad.net/~iconnor/+archive ... orageareas
asker
Post by asker » Sat May 18, 2019 9:38 pm
I just built 1.33.9 in Storage Areas on ubuntu 16. There was a problem with the ssl lib. When Isaac deploys the update, I think it should work.
DVB Hardware
Post by DVB Hardware » Sat May 18, 2019 10:38 pm
Ok thanks, will wait for update, I least I know where the problem is
Jimmy
asker
Post by asker » Sat May 18, 2019 10:55 pm
Actually, my comment was for the OP who posted the libssl issue. That was a problem. I don't know how Isaac manages the packages for different distros/etc. So I'm not sure if you will see if for Linux Mint.
DVB Hardware
Post by DVB Hardware » Sun May 19, 2019 2:01 pm
Storageareas 1.33.9~20190519084612-bionic PPA just released...upgrade success
Jimmy
Post by iconnor » Sun May 19, 2019 2:24 pm
New packages should be available now.
