I have R2 connected and get the stream working. However, can't find the right control script for the model. Anyone had any experiences on this.
Thanks in advance.
How to select PTZ control of Foscam R2
Re: How to select PTZ control of Foscam R2
YES!! I wrote one for the R2C....do you know how to set up the PTZ? the Control script is called FOSCAMR2C
__
__
looks like this:
- Screenshot(21).png (132.44 KiB) Viewed 3680 times
Hi All,
what's the exact model?
This?
https://www.foscam.it/foscam-r2m-motori ... onale.html
or this?
https://www.foscam.it/foscam-r2-motoriz ... i-110.html
Do you confirm that it works in ZoneMinder with PTZ control?
Thank you!
This?
or this?
Thank you!
