Montage view in popup
mcll
Post by mcll »
Hi!
I'm running v1.33.2. Is there any way to show montage or the camera picture in popup window? When i click on "Montage" the montage view shows in the same window. Before it was shown in a popup window without menu, etc. Right click and select new window is not an option, because the complete menu, etc is also shown there.
How could i set it to show those links in popup? I did not find any settings for that.
Thanks!
Greetings,
Laszlo
Ubuntu Server 14.04.3LTS 64bit - ZoneMinder v1.32.3 - 2x AV-Tech AVN257 IP Cam; 1x Hikvision DS-2CD2020F-I IP Cam
Re: Montage view in popup
you can put navbar=0 in the url.
mcll
Post by mcll »
Thanks, but how, and where the put it?
Greetings,
Laszlo
using navbar=0 in the url is not creating a popout window with the montage like it did up to version 1.30.4 and I think 1.31.1 did as well.
@mcll
the url would look like this ->
http://localhost/zm/index.php?view=montage&navbar=0
