Zoneminder compiled from GIT (dates newer than 6. 1. 2019), fresh install Mariadb & Zoneminder.
mysql Ver 15.1 Distrib 10.3.12-MariaDB, for Linux (x86_64) using readline 5.1
After creating a new camera and try to start zoneminder, debug info show:
01/20/19 19:57:53.686648 zms_m1[27601].DB1-zm_monitor.cpp/2331 [Loaded monitor 1(jug-VGA), 1 zones]
01/20/19 19:57:53.686674 zms_m1[27601].DB3-zm_monitor.cpp/521 [Connecting to monitor. Purpose is 0]
01/20/19 19:57:53.686706 zms_m1[27601].DB3-zm_monitor.cpp/528 [Success opening mmap file at (/dev/shm/zm.mmap.1)]
01/20/19 19:57:53.686724 zms_m1[27601].ERR-zm_monitor.cpp/542 [Got empty memory map file size 0, is the zmc process for this monitor running?]
01/20/19 19:57:53.697259 zms_m1[27601].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
01/20/19 19:57:53.703350 zms_m1[27601].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
01/20/19 19:57:53.705932 zms_m1[27601].DB1-zm_logger.cpp/255 [Terminating Logger]
[/usr/src/zoneminder] # ls -la /dev/shm
total 0
drwxrwxrwt 2 root root 60 Jan 20 20:22 .
drwxr-xr-x 15 root root 5080 Jan 20 10:41 ..
-rw------- 1 apache apache 0 Jan 20 19:57 zm.mmap.1
