Page 1 of 1
packing ZM-1.33.x for a Slackware
Posted: Fri Jan 18, 2019 8:54 am
by zd59
Hi!
I'm testing/using a ZM on a Slackware Linux.
Everything working fine until ZM GIT source somewhere after 6. 1. 2019.
ZM-GIT compiled after that day the application do not work - can not start Zoneminder from GUI (Run State change).
In a logs is a line:
Got empty memory map file size 0, is the zmc process for this monitor running?
and I got empty camera cache file in /dev/shm:
-rw------- 1 apache apache 0 Jan 17 22:24 zm.mmap.1
Tests performed with complete delete of all traces of zoneminder and fresh SQL database on every single test:
zm-1.33.x GIT sources compiled and working OK for the following dates:
25. 12. 2018 - database 1.33.0
6. 1. 2019 - database 1.33.1 (the last until now)
failed GIT compiled ZM (both with above error described)
16. 1. 2019 - database 1.33.1
17. 1. 2019 - database 1.33.1
So the last working GIT I tested was at 6. 1. 2019
Suspecting you recently changed/added some dependencies, variables in configuration files, httpd/php config files, changes in SQL database etc.
Please write regarding changes that have been done since 6. 1. 2019.
If debug logs needed, I need some advice to set up ZM, default logs do not show any usable info.
Best regards to developers!
Re: packing ZM-1.33.x for a Slackware
Posted: Wed Jan 30, 2019 9:21 pm
by zd59
This case is closed.
Obviously I discovered a bug :oops: that was solved today by iconnor: BIG thanks! :D :D
https://github.com/ZoneMinder/zoneminde ... 87ac421cbf
Wondering why nobody of developers reply to that topic. :cry: Maybe like "it's a bug we work on it." Had a hard time and huge amount of lost time searching/testing what's wrong.
