Page 1 of 1
Negative Event Count
Posted: Mon Dec 17, 2018 2:46 pm
by geraldbrandt
I just upgraded from 1.32.2 and got 1.33.0. Didn't expect it, but my fault for not changing my repo. No big deal, I don't mind testing.
One of my cameras has a negative event count of -7 and a negative size value. When I record an event, the count goes to -6, etc.
What can I do on my end to help you figure it out (if you need help)?
Gerald
Re: Negative Event Count
Posted: Mon Dec 17, 2018 3:56 pm
by rockedge
I see this same occurrence only when I compile ZM 1.33.0 from source. When I use the iconner PPA the negative event counts and zero zones being displayed do not happen.
Posted: Mon Dec 17, 2018 7:42 pm
by geraldbrandt
I upgraded from the iconnor ppa.
Posted: Mon Dec 31, 2018 4:35 pm
by knight-of-ni
Isaac and I have seen this too, but not on every system we are running.
It seems to right itself over time, which actually makes it harder to troubleshoot.
Added to our task list:
https://github.com/ZoneMinder/zoneminder/projects/2
Posted: Fri Jan 04, 2019 9:37 pm
by geraldbrandt
My system is still showing -8 when there are no events. Is there anything I can do to help debug this?
Gerald
Posted: Sun Jan 06, 2019 6:14 pm
by knight-of-ni
Try this:
viewtopic.php?f=38&t=27886#p108869
Verify all three timezones are reporting the same offset.
Then also try re-running zmupdate in the manner shown here:
viewtopic.php?f=38&t=27622&p=108402&hil ... .4#p108402
At the moment, we still have not determined the cause.
