Page 1 of 1
Zip compression problems
Posted: Sat Dec 15, 2018 2:31 pm
by zmeggyesi
Following Connor's suggestion to a previous issue, I built a copy of ZoneMinder from the master branch (commit 5a6e700c456176fe2eedc4065caaf9725caae00a), which managed to fix the issue at hand, but also shed light on another one in which ZM cannot create the ZIP file for upload. On running the filter with the Perl debugger enabled, I don't see anything glaringly obvious, but given my lack of knowledge of Perl, that's not saying much. Stacktrace of the filter crash:
Can't call method "desiredCompressionLevel" on an undefined value at /usr/share/perl5/Archive/Zip/Archive.pm line 260.
        Archive::Zip::Archive::addFile(Archive::Zip::Archive=HASH(0x29a7810), "/mnt/external/6/2018-12-15/8443/snapshot.jpg") called at /usr/bin/zmfilter.pl line 509
        main::uploadArchFile(ZoneMinder::Filter=HASH(0x2806c90), ZoneMinder::Event=HASH(0x29a71c8)) called at /usr/bin/zmfilter.pl line 325
        main::checkFilter(ZoneMinder::Filter=HASH(0x2806c90)) called at /usr/bin/zmfilter.pl line 209
Rolling back the version for a short time, I can see that this has been present in 1.32.3, it just didn't come up for me because of an issue with shallow storage paths.
Anyone have any ideas as to what could be at play here?
Re: Zip compression problems
Posted: Sat Dec 15, 2018 3:47 pm
by rockedge
some variable is not being set ...looks like perhaps the compression level? So when "desiredCompressionLevel" is called by /usr/share/perl5/Archive/Zip/Archive.pm line 260, the value that sets the level is missing.
Posted: Sat Dec 15, 2018 3:51 pm
by zmeggyesi
Yes, that much I gathered. The thing is, I don't see anywhere on the UI where the compression level may be set...
Posted: Mon Dec 17, 2018 1:02 pm
by zmeggyesi
I tested disabling compression from the Options screen, but that didn't help, I still got the exact same stacktrace...
