I have a new PI with 16GB SD card fresh installtion .
I went by this guide
https://wiki.zoneminder.com/Raspberry_Pi_4_-_Raspbian
the only "new" setting I put is the mysql password for root he ask me while running
sudo mysql_secure_installation
I can see the apache2 is up (because when I enter http://10.0.0.100 I get hte apache2 web page )
but the zonminder service is not working (http://10.0.0.100/zm) - error 404 no usch webpage.
what did I miss?
pi@raspberrypi:~$ sudo systemctl status zoneminder.service
zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-12-26 10:04:44 IST; 5min ago
Docs: http://zoneminder.readthedocs.org/en/latest/
Process: 1019 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 2672 (zmdc.pl)
Tasks: 3 (limit: 2200)
Memory: 30.9M
CGroup: /system.slice/zoneminder.service
2672 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
5583 /usr/bin/perl -wT /usr/bin/zmwatch.pl
5781 /usr/bin/perl -wT /usr/bin/zmstats.pl
Dec 26 10:09:19 raspberrypi zmaudit[26807]: FAT [zmaudit.pl appears to already be running at pid 5352. If not, please delete /var/run/zm/zmaudit.pid or use the --force command
Dec 26 10:09:20 raspberrypi zmdc[2672]: ERR ['zmaudit.pl -c' exited abnormally, exit status 255]
Dec 26 10:09:28 raspberrypi zmdc[2672]: INF [Starting pending process, zmfilter.pl --filter_id=2 --daemon]
Dec 26 10:09:28 raspberrypi zmdc[2672]: INF ['zmfilter.pl --filter_id=2 --daemon' starting at 19/12/26 10:09:28, pid = 27595]
Dec 26 10:09:28 raspberrypi zmdc[27595]: INF ['zmfilter.pl --filter_id=2 --daemon' started at 19/12/26 10:09:28]
Dec 26 10:09:29 raspberrypi zmdc[2672]: ERR ['zmfilter.pl --filter_id=2 --daemon' exited abnormally, exit status 9]
Dec 26 10:09:34 raspberrypi zmdc[2672]: INF [Starting pending process, zmfilter.pl --filter_id=1 --daemon]
Dec 26 10:09:35 raspberrypi zmdc[27978]: INF ['zmfilter.pl --filter_id=1 --daemon' started at 19/12/26 10:09:35]
Dec 26 10:09:35 raspberrypi zmdc[2672]: INF ['zmfilter.pl --filter_id=1 --daemon' starting at 19/12/26 10:09:35, pid = 27978]
Dec 26 10:09:41 raspberrypi zmdc[2672]: ERR ['zmfilter.pl --filter_id=1 --daemon' exited abnormally, exit status 9]
Thanks ,
