Email ZM1.32.3
nonobike
Email ZM1.32.3
Post by nonobike » Wed Dec 04, 2019 6:36 am
I peeled the whole forum, I managed to install zoneminder on ubuntu , to set everything I wanted :)
I want to thank everyone for sharing and helping.
I created a filter that sent me my detections of movement by email. the problem is the script does not turn into a background spot ...
I have to run to be warned ... so utility is less ...
do you have another filter on event creation can be?
I would like not to see to install script .. use the functions of ZM for ease future maintenance.
Thank you for your help
snake
Re: Email ZM1.32.3
Post by snake » Wed Dec 04, 2019 2:45 pm
https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
https://wiki.zoneminder.com/SMS_Notific ... ple_Filter
It is possible to run the email filters in the background. See the example filter. You may be missing the -1 minute. Beware of sending anymore than 1 results. When 1 result is sent, it will not send again - it's marked in the db, and you need a new event.
nonobike
Re: Email ZM1.32.3
Post by nonobike » Thu Dec 05, 2019 7:03 am
Hello and thank you
Example Filter
Weekday equal to Saturday OR
Weekday equal to Sunday AND
so I used:
date / time greater than or equal to -1 minute AND
as I wish to watch every day!
I try this new configuration and come back to you
nonobike
Re: Email ZM1.32.3
Post by nonobike » Thu Dec 05, 2019 3:49 pm
It does not work ...
The criteria of my old filter are valid. when I manually execute it I receive the alarms! How can I verify that it turns out well in the background?
Thank you
snake
Re: Email ZM1.32.3
Post by snake » Sat Dec 07, 2019 12:37 am
Those two links have all the troubleshooting instructions you need
e.g.
from: https://wiki.zoneminder.com/SMS_Notific ... _the_email
"First, run a filter in the background (see tips below). Do not try to submit / execute. Second, Enable logging on /var/log/zm folder. Third, tail the ZMFilter log and syslog. Fourth, to initiate an alarm (if alarms are used to test emails), use 'force alarm' on the monitor screen. That is, view a camera, and click force alarm.
You should see SSMTP send an email on the syslog (or try) and the zmfilter log will report the trigger."
It appears that English is not your first language, so let me know if it is not clear, and possibly try online translation.
