Hi there,
I have tried a lot of configurations for my GV800 16 Channel (BT787a) to work alongside ubuntu 18.04 LTS and Zoneminder 1.32. I cant succeed streaming all channels same time on input1 (/dev/video0). Shows the same camera over all channels.
Please could you give me some advice?
GV800
https://imge.to/i/v4P0Ni
/etc/modprobe.d/bttv.conf
# i2c
alias char-major-89 i2c-dev
options i2c-core i2c_debug=1
options i2c-algo-bit bit_test=1
# bttv
alias char-major-81 videodev
options bttv card=157,158,158,158 tuner=4,4,4,4 radio=0
Zoneminder > options
V4L_MULTI_BUFFER - unchecked
CAPTURES_PER_FRAME - empty
Monitor >Source
Capture Method - Video4Linux version 2
Device Format - NTSC
Multi Buffering - No
Captures Per Frame - 2
https://imge.to/i/v4PnvF
Final result: same channel over all otehrs.
https://imge.to/i/v4PKxV
GV800 16 CH shows the same image over all channels
Re: GV800 16 CH shows the same image over all channels
You are better off using an IP Video Encoder instead of bttv cards.
See: https://wiki.zoneminder.com/Hardware_Co ... eo_Encoder
Used ones can be obtained for reasonable prices.
