I am trying to add LaView POE Dome camera's to my Zoneminder running on Unraid server. When i go to ONVIF to probe and find Camera it doesnt find any camera. I am Camera configuration i cant find RTSP url for camera either so not sure how to configure it in Zoneminder. Does anyone have LaView camera's configured with Zoneminder?
My Camera Models are : lv-pd51208c and lv-pdk50812a.
Thanks in advance.
Help with adding LaView POE Camera
Re: Help with adding LaView POE Camera
I have the LV-PD5V108. You can try adding the cameras manually.
Under the source tab, enter the SOURCE PATH:
rtsp://username:password@xxxx.xxxx.xxxx.xxxx:554
enter the camera's username, password and IP.
If the port (554) did not work, try doing a port scan on the camera's IP.
