Unable to connect to zmc process for monitor
rangerbob
Post by rangerbob » Sun Jun 30, 2019 3:20 am
I deleted a camera. monitor 7 or zms_m7 and I have 8 cams and none of them because I deleted 7 are numbered 7 but for some reason it is still trying to use it .. all my cams are fine but I get this in the logs
Jun 29 23:16:53 gfzm zms_m7[28919]: ERR [zms_m7] [Bogus number of lines return from query, 0 returned for query SELECT Id, Name, ServerId, StorageId, Type, Function+0, Enabled, LinkedMonitors, AnalysisFPSLimit, AnalysisUpdateDelay, MaxFPS, AlarmMaxFPS,Device, Channel, Format, V4LMultiBuffer, V4LCapturesPerFrame, Protocol, Method, Options, User, Pass, Host, Port, Path, Width, Height, Colours, Palette, Orientation+0, Deinterlacing, RTSPDescribe, SaveJPEGs, VideoWriter, EncoderParameters, RecordAudio, Brightness, Contrast, Hue, Colour, EventPrefix, LabelFormat, LabelX, LabelY, LabelSize,ImageBufferCount, WarmupCount, PreEventCount, PostEventCount, StreamReplayBuffer, AlarmFrameCount, SectionLength, FrameSkip, MotionFrameSkip, FPSReportInterval, RefBlendPerc, AlarmRefBlendPerc, TrackMotion, Exif, SignalCheckPoints, SignalCheckColour FROM Monitors WHERE Id=7.]
Jun 29 23:16:53 gfzm zms_m7[28919]: ERR [zms_m7] [Can't use query result: ]
Jun 29 23:16:53 gfzm zms_m7[28919]: ERR [zms_m7] [Unable to load monitor id 7 for streaming]
Jun 29 23:16:53 gfzm zms_m7[28919]: ERR [zms_m7] [Unable to connect to zmc process for monitor 7]
how do I remove this monitor 7 that no longer exists
My system crashed not sure what for I am hoping its not because of these repeating errors every min
