RSTP and Foscam FI9900P
3gem
Post by 3gem »
Hi all I am attempting to migrate from 1.29.0 to 1.32.x and am getting an error when I setup RSTP and Foscam FI9900P it works great in 1.29.0, but 1.32.x throws the following error: Unexpected response code 400, text is 'Bad Request' zm_rtsp.cpp.
I attempted the ffmpeg option but was unsuccessful. I have verified the stream with VLC and it works. For now I am sticking with 1.29.0 until I can find a fix.
Any recommendations?
Thanks,
DerGraf
Re: RSTP and Foscam FI9900P
Post by DerGraf »
My source settings for 9900P:
Source path: rtsp://user:pass@192.168.xxx.xxx:88/videoMain
Method: TCP
Colorspace: 32bit
Width: 1920
Height: 1080
Works fine. Hope it helps.
3gem
Post by 3gem »
That did the trick. i neglected the rtsp:// initially when I used the ffmpeg option.
Thank you
