zoneminder wrong timesetamp
zmuser2018
Post by zmuser2018 » Sun Jun 02, 2019 6:13 pm
Hi everyone
I've been messing around with zoneminder all day and I finally got it working
There are still several things I need to do but I'm trying to do it one step at the time
Need to set more specific motion detection
Need to set the recording time for a motion detection(as it currently records only for a few seconds when it detects something)
Need to set access from mobile and externally
Need to alert notification
I'm still searching on the above but as information seems to be scattered all over the place and honestly I don't find zoneminder documentation that helpful
The first thing I want to do is set the timestap as is showing it incorrectly
Here's what I've done when
Ran docker with Europe/London timezone
docker run -d --shm-size=4096m -e TZ=Europe/London -e ZM_DB_HOST=db --net net --name zm -p 80:80 quantumobject/docker-zoneminder
I checked if the php.ini file has the correct timezone in the docker shell
docker exec -it <mycontainer> bash
nano etc/php/7.2/apache2/php.ini
The above is set to Europe/London
Checked the timezone in
/etc/timezone
It was set to Etc/UTC
so I changed it to Europe/London
Stopped both my mysql and zoneminder container and restarted, the timestamp is still wrong
Any idea what I'm missing?
Re: zoneminder wrong timesetamp
Post by bbunge » Mon Jun 03, 2019 2:19 pm
Are you sure the time is coming from Zoneminder? Or is it the camera time in the image?
Other suggestion is to not run in Docker...
Ilia_SB
Post by Ilia_SB » Wed Jun 05, 2019 8:12 pm
Check the whole php.ini file. Mine had one more timezone line at the very end. Or just run php_info and see if php outputs the correct timezone.
Post by bbunge » Wed Jun 05, 2019 8:36 pm
If you use one of my install scripts the date entry will be appended to the php.ini file. For most this will not be an issue.
Users browsing this forum: No registered users and 5 guests
