h265 event view issue
andrew-yu
Post by andrew-yu »
I added 2 cheap chinenese cams with h265 codec support. I turned on H265 on them. I setup them as Mocord with "H264 Camera Passthrough" camera writer in Zoneminder.
Now i can watch real-time video from them. Also they are avaliable at montage review. But if i try to watch any event from them (directly from archive or by selecting by mouse in montage review) i get black screen with [X] (but files are present - i can download them and watch locally).
Is it an old issue with h265 browser support?
detxm80
Re: h265 event view issue
Post by detxm80 »
it's an issue, look my and pat2 posts. We think it's an ARM issue, but try other platform the result is the same
Yes your browser cannot play h265. Upgrade to latest master snapshot and you will be able to view them as a jpeg stream.
