Page 1 of 1
Video's speed setting is reset on each new event's view
Posted: Sat Mar 23, 2019 9:37 pm
by andrew-yu
Video's speed setting is reset on each new event's view. It's very annoying in gapless view mode.
Re: Video's speed setting is reset on each new event's view
Posted: Sat Mar 23, 2019 10:20 pm
by rockedge
are you suggesting a change? so once set it stays that way for the next event?
Posted: Sun Mar 24, 2019 5:47 am
by andrew-yu
Sure, it should works like it was at old good days.
I'm using 3 PC with Zoneminder. Two with 1.32 and one with 1.29 with old GUI.
If i need to find when something happened, for example, in one week, on 1.29 i can turn on 4x or 10x speed and watch all events in gapless mode. Speed setting saves until i close the window.
With 1.32 i should set speed to each new event even in gapless mode.
Posted: Sun Mar 24, 2019 9:27 am
by c128
viewtopic.php?f=38&t=27734
Nut-shell: a fix is currently present in master and so v1.33.4.
I'd guess that'll turn up in v1.32.4 for this release series.
Posted: Sun Mar 24, 2019 10:27 am
by andrew-yu
Thanks for the link. Great news.
