Solution for multi analog via USB?
BobLaske
Post by BobLaske » Mon Mar 18, 2019 7:46 pm
I've been looking for a way to connect analog cameras into my system which is a mini PC with no PCI slots.
Therefore, I need something that can connect via USB.
I've come across those cheap EasyCap devices but have read that they do only 1FPS which is useless.
Wondering if others have had to deal with this and what you've used as your solution.
snake
Re: Solution for multi analog via USB?
Post by snake » Mon Mar 18, 2019 8:37 pm
No need for USB, you can have an IP video encoder on the same network.
https://wiki.zoneminder.com/Hardware_Co ... eo_Encoder
BobLaske
Post by BobLaske » Mon Mar 18, 2019 8:47 pm
Yes, I have some of those also but need a way to add analog cameras using USB. Mainly, it is to see if it can be done.
The only four channel I have is a GXV3504 Grandstream but I'd like to see what could be used via one single USB port.
I've tried connecting multiple local USB cams but that never works, always some sort of shared memory and other errors.
BobLaske
Post by BobLaske » Wed Apr 10, 2019 7:11 pm
So the question remains. How can multiple USB cameras be installed?
viewtopic.php?f=38&t=28151&p=110151#p110151
