Edit: This was solved and came back, and then solved again. See post 5.
Fresh install of 1.32.3 on Ubuntu Server 18.04 following this guide
I'm able to view the stream in VLC with no issues, and when testing yesterday on a docker container running 1.33.1 everything worked great. /dev/shm is only at 5% use and this is the only camera I have enabled. The camera is a WyzeCam v2 running the Xiaomi-Dafang firmware.
I do see an error in the logs
Socket /var/run/zm/zms-886903s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.
2019-02-10 08:52:52 zmc_m2 4170 INF Cam1: images:6100 - Capturing at 25.00 fps, capturing bandwidth 521932bytes/sec zm_monitor.cpp 2477
2019-02-10 08:52:48 zmc_m2 4170 INF Cam1: images:6000 - Capturing at 25.00 fps, capturing bandwidth 524739bytes/sec zm_monitor.cpp 2477
2019-02-10 08:52:44 zmc_m2 4170 INF Cam1: images:5900 - Capturing at 20.00 fps, capturing bandwidth 394033bytes/sec zm_monitor.cpp 2477
2019-02-10 08:52:39 zmc_m2 4170 INF Cam1: images:5800 - Capturing at 25.00 fps, capturing bandwidth 534370bytes/sec zm_monitor.cpp 2477
2019-02-10 08:52:35 zmc_m2 4170 INF Cam1: images:5700 - Capturing at 25.00 fps, capturing bandwidth 497959bytes/sec zm_monitor.cpp 2477
2019-02-10 08:52:31 zmc_m2 4170 INF Cam1: images:5600 - Capturing at 20.00 fps, capturing bandwidth 399653bytes/sec
And there is a socket in /var/run/zm but of a different name than the one in the logs
# ll /var/run/zm
total 8
drwxr-xr-x 2 www-data www-data 100 Feb 10 14:48 ./
drwxr-xr-x 32 root root 1080 Feb 10 14:32 ../
-rw-r--r-- 1 www-data www-data 4 Feb 10 14:01 zmaudit.pid
srwxr-xr-x 1 www-data www-data 0 Feb 10 14:01 zmdc.sock=
-rw-r--r-- 1 www-data www-data 4 Feb 10 14:01 zm.pid
