API Problem after update vom 1.30
wtfka
Post by wtfka » Tue Jan 15, 2019 7:18 am
I have updated Zoneminder from 1.30 to 1.32 on an Ubuntu 16.04 Server Installation. Everything works fine (monitors, events, capturing, ...) but zmninja cannot connect ("Check your Credentials"). For testing i have disabled authentication, but i think its a problem with the API:
http://server/zm/api/host/getVersion.json
    "version": "1.32.3",
    "apiversion": "1.0"
http://server/zm/api/host/monitors.json
    "success": false,
    "data": {
        "code": 404,
        "name": "Action HostController::monitors() could not be found.",
        "message": "Action HostController::monitors() could not be found.",
        "url": "\/zm\/api\/host\/monitors.json",
        "exception": {
            "class": "MissingActionException",
            "code": 404,
            "trace": [
                "#0 \/usr\/share\/zoneminder\/www\/api\/app\/Plugin\/Crud\/Lib\/CrudControllerTrait.php(31): Controller->invokeAction(Object(CakeRequest))",
                "#1 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Routing\/Dispatcher.php(193): AppController->invokeAction(Object(CakeRequest))",
                "#2 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Routing\/Dispatcher.php(167): Dispatcher->_invoke(Object(HostController), Object(CakeRequest))",
                "#3 \/usr\/share\/zoneminder\/www\/api\/app\/webroot\/index.php(107): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))",
                "#4 {main}"
        "queryLog": []
Any Ideas?
sorry for my bad english
k-sudak
Re: API Problem after update vom 1.30
Post by k-sudak » Sat Feb 16, 2019 7:16 pm
Have you got this output in your browser?
"apiversion": "1.0"
I have the same problem, read that "http://server/zm/api/host/getVersion.json" should be opened in the same browser where you are already logged in to your ZM server.
k-sudak
Post by k-sudak » Sat Feb 16, 2019 7:18 pm
Actually, I have just an empty page in output :(
Don't know how to fix the permissions.
Already run # chown -R www-data:www-data /usr/share/zoneminder/www/api but the result same.
Post by bbunge » Sun Feb 17, 2019 12:20 am
    "apiversion": "1.0"
    "success": false,
    "data": {
        "code": 404,
        "exception": {
            "code": 404,
            "trace": [
                "#4 {main}"
        "queryLog": []
Any Ideas?
Make sure in ZmNinja Settings/path to cgi-bin you have http://serverip/zm/cgi-bin
Just did an upgrade on Ubuntu 16.04 ZM 1.30.4 to 1.32.3 with no issues. ZmNinja works, too.
The upgrade is simple: add the 1.32.x PPA, service zoneminder stop, apt update, apt upgrade, service zoneminder start
k-sudak
Post by k-sudak » Sun Feb 17, 2019 1:07 pm
I can't upgrade so simple, because there is for Raspbian-stretch no any packets with v1.32.3
Any recommendations?
Post by rockedge » Sun Feb 17, 2019 1:29 pm
try this: in a browser login to ZM and then open a new tab or window and then run http://server/zm/api/host/monitors.json
what seems to be happening is the authorization for the API response is missing.....not logged in.
the getVersion.json giving a reponse means the API is working okay,
