zmcontrol.pl
kobold81
zmcontrol.pl
Post by kobold81 » Mon Jan 14, 2019 7:45 pm
I managed to get the video from the dahua ipc-A35 but ptz is not available.
The log says "Error check failed:'401 Unauthorized'" and running zmcontrol.pl directly gives me the following warnings:
WARNING: ZoneMinder configuration file found but is not readable. Check file permissions on /etc/zm/zm.conf
WARNING: ZoneMinder configuration file found but is not readable. Check file permissions on /etc/zm/conf.d/zmcustom.conf
Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_HOST"} in pattern match (m//) at /usr/share/perl5/ZoneMinder/Config.pm line 93.
Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_HOST"} in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Config.pm line 102.
Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Config.pm line 117.
DBI connect('database=;host=','',...) failed: Access denied for user 'marc'@'localhost' (using password: NO) at /usr/share/perl5/ZoneMinder/Config.pm line 117.
Can't connect to db at /usr/share/perl5/ZoneMinder/Config.pm line 166.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 166.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmcontrol.pl line 27.
BEGIN failed--compilation aborted at /usr/bin/zmcontrol.pl line 27.
Is there a way to use zmcontrol with the dahua.pm directly r to narrow down the possible source of this probem?
kobold81
Re: zmcontrol.pl
Post by kobold81 » Wed Jan 16, 2019 10:22 pm
sorry, doing sudo zmcontrol.pl fixes the errors connected to zmcontrol.
Has anyone a clue how to test the dahua.pm to find out where the 401 comes from?
kobold81
Re: zmcontrol.pl
Post by kobold81 » Wed Jan 16, 2019 10:37 pm
when using Dahua-pm, usr/bin/zmcont hogs 94% of available memory and the server hangs....
Sometimes, log just shows
Can't access moveConRight member of object of class ZoneMinder::Control::Dahua
kobold81
Re: zmcontrol.pl
Post by kobold81 » Thu Jan 17, 2019 12:01 am
I have adapted the Dahua.pm to actually work with my Dahua IPC-A35 by including snippets from bobylapointe69300 (viewtopic.php?f=9&t=27000&p=104601&hilit=dahua#p104601)
# CGI Control Protocol
# This module is using code from bobylapointe69300
# viewtopic.php?f=9&t=27000&p=104601&hilit=dahua#p104601
#Control Address field on Control tab should be like :
# Field 'Controll Address' in Monitor Options
# -> contains: admin:password@192.168.1.XX:80
# -> must not contain: http:// or https://
# -> adjust with your own parameters (IP, port, username and password)
# Control Capabilities for 'Dahua' has
# -> in field 'Protocol' the value: Dahua
# This module works if URL of camera control contains '/cgi-bin/ptz.cgi?'
# for commands see 'DAHUA HTTP API FOR IPC Version 1.67'
# e.g. found at https://www.telecamera.ru/bitrix/compon ... n=download
package ZoneMinder::Control::Dahua;
use 5.8.0;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
our $REALM = '';
our $USERNAME = '';
our $PASSWORD = '';
our $ADDRESS = '';
our $PROTOCOL = 'http://';
use Time::HiRes qw(usleep);
use ZoneMinder::Database qw(zmDbConnect);
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
# The Dahua camera firmware API supports the concept of having multiple
# channels on a single IP controller.
# As most cameras only have a single channel, and there is no similar
# information model in Zoneminder, I'm hardcoding the first and default
# channel "0", here.
$self->{dahua_channel_number} = "0";
if ( ( $self->{Monitor}->{ControlAddress} =~ /^(?<PROTOCOL>http?:\/\/)?(?<USERNAME>[^:@]+)?:?(?<PASSWORD>[^\/@]+)?@?(?<ADDRESS>.*)$/ ) ) {
$PROTOCOL = $+{PROTOCOL} if $+{PROTOCOL};
$USERNAME = $+{USERNAME} if $+{USERNAME};
$PASSWORD = $+{PASSWORD} if $+{PASSWORD};
$ADDRESS = $+{ADDRESS} if $+{ADDRESS};
} else {
Error('Failed to parse auth from address ' . $self->{Monitor}->{ControlAddress});
$ADDRESS = $self->{Monitor}->{ControlAddress};
if ( !($ADDRESS =~ /:/) ) {
Error('You generally need to also specify the port. I will append :80');
$ADDRESS .= ':80';
use LWP::UserAgent;
$self->{ua}->agent("ZoneMinder Control Agent/".$ZoneMinder::Base::ZM_VERSION);
$self->{state} = 'closed';
# credentials: ("ip:port" (no prefix!), realm (string), username (string), password (string)
Debug("sendCmd credentials control address:'".$ADDRESS
."' realm:'" . $REALM
. "' username:'" . $USERNAME
. "' password:'".$PASSWORD
$self->{ua}->credentials($ADDRESS, $REALM, $USERNAME, $PASSWORD);
# Detect REALM
my $get_config_url = $PROTOCOL . $ADDRESS . "/cgi-bin/configManager.cgi?action=getConfig&name=Ptz";
my $req = HTTP::Request->new(GET=>$get_config_url);
if ($res->is_success) {
$self->{state} = 'open';
return;
if ( $res->status_line() eq '401 Unauthorized' ) {
my $headers = $res->headers();
foreach my $k (keys %$headers) {
Debug("Initial Header $k => $$headers{$k}");
if ($$headers{'www-authenticate'}) {
my ($auth, $tokens) = $$headers{'www-authenticate'} =~ /^(\w+)\s+(.*)$/;
if ($tokens =~ /\w+="([^"]+)"/i) {
if ($REALM ne $1) {
$REALM = $1;
Debug("Changing REALM to '" . $REALM . "'");
if ($res->is_success()) {
return;
Debug('Authentication still failed after updating REALM' . $res->status_line);
foreach my $k ( keys %$headers ) {
} # end foreach
} else {
Error('Authentication failed, not a REALM problem');
} else {
Error('Failed to match realm in tokens');
} # end if
} else {
Error('No WWW-Authenticate Header');
} # end if headers
} # end if $res->status_line() eq '401 Unauthorized'
sub close
my $self = shift;
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendGetRequest {
my $self = shift;
my $url_path = shift;
my $result = undef;
my $url = $PROTOCOL . $ADDRESS . $url_path;
my $req = HTTP::Request->new(GET=>$url);
$result = !undef;
} else {
if ($res->status_line() eq '401 Unauthorized') {
Debug("Error check failed, trying again: USERNAME: $USERNAME realm: $REALM password: " . $PASSWORD);
Debug("Content was " . $res->content() );
$result = !undef;
} else {
Error("Content was " . $res->content() );
if ( ! $result ) {
Error("Error check failed: '".$res->status_line());
return($result);
sub sendPtzCommand
my $self = shift;
my $action = shift;
my $command_code = shift;
my $arg1 = shift;
my $arg2 = shift;
my $arg3 = shift;
my $channel = $self->{dahua_channel_number};
my $url_path = "/cgi-bin/ptz.cgi?";
$url_path .= "action=" . $action . "&";
$url_path .= "channel=" . $channel . "&";
$url_path .= "code=" . $command_code . "&";
$url_path .= "arg1=" . $arg1 . "&";
$url_path .= "arg2=" . $arg2 . "&";
$url_path .= "arg3=" . $arg3;
$self->sendGetRequest($url_path);
sub sendMomentaryPtzCommand
my $self = shift;
my $arg1 = shift;
my $arg2 = shift;
my $arg3 = shift;
my $duration_ms = shift;
$self->sendPtzCommand("start", $command_code, $arg1, $arg2, $arg3);
my $duration_ns = $duration_ms * 1000;
usleep($duration_ns);
$self->sendPtzCommand("stop", $command_code, $arg1, $arg2, $arg3);
##added code
#Control URL to camera :
#example for moving camera 'Up' -> "cgi-bin/ptz.cgi?action=start&channel=0&code=Up&arg1=0&arg2=1&arg3=0&arg4=0";
# Reboot the Camera
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "cgi-bin/magicBox.cgi?action=reboot";
$self->sendGetRequest($cmd);
#Left Arrow
sub moveConLeft
my $self = shift;
Debug("Move Up Left");
$self->sendMomentaryPtzCommand("Left", 0, 1, 0, 0);
#Right Arrow
sub moveConRight
my $self = shift;
Debug( "Move Right" );
$self->sendMomentaryPtzCommand("Right", 0, 1, 0, 0);
#Up Arrow
sub moveConUp
my $self = shift;
# you can change the speed of movement 1-8 with arg 2, same for Down, Right...
Debug( "Move Up" );
$self->sendMomentaryPtzCommand("Up", 0, 1, 0, 0);
#Down Arrow
sub moveConDown
my $self = shift;
Debug( "Move Down" );
$self->sendMomentaryPtzCommand("Down", 0, 1, 0, 0);
#Zoom In
sub zoomConTele
my $self = shift;
Debug( "Zoom Tele" );
$self->sendMomentaryPtzCommand("ZoomTele", 0, 1, 0, 0);
#Zoom Out
sub zoomConWide
my $self = shift;
Debug( "Zoom Wide" );
$self->sendMomentaryPtzCommand("ZoomWide", 0, 1, 0, 0);
#Diagonally Up Right Arrow
sub moveConUpRight
my $self = shift;
$self->sendMomentaryPtzCommand("RightUp", 1, 1, 0, 0);
#Diagonally Down Right Arrow
sub moveConDownRight
my $self = shift;
$self->sendMomentaryPtzCommand("RightDown", 1, 1, 0, 0);
#Diagonally Up Left Arrow
sub moveConUpLeft
my $self = shift;
$self->sendMomentaryPtzCommand("LeftUp", 1, 1, 0, 0);
#Diagonally Down Left Arrow
sub moveConDownLeft
my $self = shift;
$self->sendMomentaryPtzCommand("LeftDown", 1, 1, 0, 0);
#Stop, for center button on control panel
sub moveStop
my $self = shift;
Debug( "Move Stop" );
# you can put any kind of code to stop the camera, I put Up by default.
my $cmd = "cgi-bin/ptz.cgi?action=stop&channel=0&code=Up&arg1=0&arg2=1&arg3=0";
$self->sendPtzCommand("stop", 0, 0, 1, 0);
sub moveRelUpLeft
my $self = shift;
$self->sendMomentaryPtzCommand("LeftUp", 4, 4, 0, 500);
sub moveRelUp
my $self = shift;
Debug("Move Up");
$self->sendMomentaryPtzCommand("Up", 0, 4, 0, 500);
sub moveRelUpRight
my $self = shift;
Debug("Move Up Right");
$self->sendMomentaryPtzCommand("RightUp", 0, 4, 0, 500);
sub moveRelLeft
my $self = shift;
Debug("Move Left");
$self->sendMomentaryPtzCommand("Left", 0, 4, 0, 500);
sub moveRelRight
my $self = shift;
Debug("Move Right");
$self->sendMomentaryPtzCommand("Right", 0, 4, 0, 500);
sub moveRelDownLeft
my $self = shift;
Debug("Move Down Left");
$self->sendMomentaryPtzCommand("LeftDown", 4, 4, 0, 500);
sub moveRelDown
my $self = shift;
Debug("Move Down");
$self->sendMomentaryPtzCommand("Down", 0, 4, 0, 500);
sub moveRelDownRight
my $self = shift;
Debug("Move Down Right");
$self->sendMomentaryPtzCommand("RightDown", 4, 4, 0, 500);
sub zoomRelTele
my $self = shift;
Debug("Zoom Relative Tele");
$self->sendMomentaryPtzCommand("ZoomTele", 0, 0, 0, 500);
sub zoomRelWide
my $self = shift;
Debug("Zoom Relative Wide");
$self->sendMomentaryPtzCommand("ZoomWide", 0, 0, 0, 500);
sub presetClear
my $self = shift;
my $params = shift;
my $preset_id = $self->getParam($params, 'preset');
$self->sendPtzCommand("start", "ClearPreset", 0, $preset_id, 0);
sub presetSet
my $self = shift;
my $params = shift;
my $dbh = zmDbConnect(1);
my $sql = 'SELECT * FROM ControlPresets WHERE MonitorId = ? AND Preset = ?';
my $sth = $dbh->prepare($sql)
or Fatal("Can't prepare sql '$sql': " . $dbh->errstr());
my $res = $sth->execute($self->{Monitor}->{Id}, $preset_id)
or Fatal("Can't execute sql '$sql': " . $sth->errstr());
my $control_preset_row = $sth->fetchrow_hashref();
my $new_label_name = $control_preset_row->{'Label'};
$self->sendPtzCommand("start", "SetPreset", 0, $preset_id, 0);
$self->sendPtzCommand("start", "SetPresetName", $preset_id, $new_label_name, 0);
sub presetGoto
my $self = shift;
my $params = shift;
$self->sendPtzCommand("start", "GotoPreset", 0, $preset_id, 0);
1;
__END__
=head1 NAME
ZoneMinder::Control::Dahua - Perl module for Dahua cameras
=head1 SYNOPSIS
use ZoneMinder::Control::Dahua;
place this in /usr/share/perl5/ZoneMinder/Control
=head1 DESCRIPTION
This module is an implementation of the Dahua IP camera HTTP control API.
=head2 EXPORT
None by default.
=head1 COPYRIGHT AND LICENSE
Copyright (C) 2018 ZoneMinder LLC
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
=cut
