Recording problem, distorted picture, log file export problem
Post by 28061 » Mon Jan 14, 2019 7:38 pm
Hi everyone,
My CCTV recorder recently failed, so I'm trying to replace it with ZoneMinder. I think I've nearly succeeded, but would appreciate your help on the following if at all possible please.
1 - Problems with recording
All three cameras (details below) were configured using the ONVIF wizard, and seemed to install correctly. I can see all three video feeds when I click on them separately, or under montage, and can configure the motion zones without problem. Motion detection appears to be working, because the log file says so, and because the events table is populated with data in the console.
However, I can't get the record function to work - when I click on an event, I get the error "The video could not be loaded, either because the server or network failed or because the format is not supported". I've browsed to the storage location, where I find the ZM folder structure 2019-01-14->1192 for example, where there is an mp4 file just 1kb in size, and a jpg snapshot. Obviously the 1kb mp4 doesn't contain anything!
I think the relevant line in the log file says something like... (Full log below)
2019-01-14 19:24:54 zmc_m1 102549 ERR Unable to send packet at frame 107: Resource temporarily unavailable, continuing zm_ffmpeg_camera.cpp 240
2 - Bottom of camera fuzzy
In addition, when viewing either of the two 4mp cameras, there's often a large strip of the feed distorted, which can often be as much as 1/3rd of the bottom of the picture. This is shown in the picture below, but on this occasion is very mild. It's often a much larger percentage of the screen.
Camera Feed.jpg (151.75 KiB) Viewed 764 times
3 - Log file export doesn't work
When I try and export the logs, using the setting "all" - I get the following
"2019-01-14 19:30:23 web_js 49794 ERR Export request failed: 500 / Internal Server Error - exportFail() ?view=log"
System Details
ZM 1.32.3 installed inside a FreeNas 11.2-Release-U1 jail, with storage mounted to a CCTV pool.
I have three cameras, of two different makes\models. One is a 1080p Chinese generic WiFi PTZ camera (The device ID is "PPCN337465SBMPC"), the other two a slightly older model of these - https://www.cctv-global.co.uk/dm40ip12v30r.
Logs
As best as I can, given the comment above...
2019-01-14 19:32:50.119950 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 10400 - Analysing at 20.00 fps]
2019-01-14 19:32:50.085134 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:11600 - Capturing at 25.00 fps, capturing bandwidth 279137bytes/sec]
2019-01-14 19:32:48.784405 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10700 - Analysing at 25.00 fps]
2019-01-14 19:32:48.535650 zmfilter_2[53386].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-01-14 19:32:48.124628 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:11600 - Capturing at 25.00 fps, capturing bandwidth 292247bytes/sec]
2019-01-14 19:32:47.830430 zmfilter_1[53382].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-01-14 19:32:46.077346 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:11500 - Capturing at 20.00 fps, capturing bandwidth 217865bytes/sec]
2019-01-14 19:32:45.883427 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 10300 - Analysing at 20.00 fps]
2019-01-14 19:32:44.715288 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10600 - Analysing at 25.00 fps]
2019-01-14 19:32:44.124889 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:11500 - Capturing at 25.00 fps, capturing bandwidth 298064bytes/sec]
2019-01-14 19:32:41.423628 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:11400 - Capturing at 25.00 fps, capturing bandwidth 295503bytes/sec]
2019-01-14 19:32:40.675345 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 10200 - Analysing at 25.00 fps]
2019-01-14 19:32:40.306428 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10500 - Analysing at 25.00 fps]
2019-01-14 19:32:40.126271 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:11400 - Capturing at 25.00 fps, capturing bandwidth 297318bytes/sec]
2019-01-14 19:32:37.410380 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:11300 - Capturing at 25.00 fps, capturing bandwidth 297078bytes/sec]
2019-01-14 19:32:36.465370 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 10100 - Analysing at 20.00 fps]
2019-01-14 19:32:36.125240 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:11300 - Capturing at 25.00 fps, capturing bandwidth 297819bytes/sec]
2019-01-14 19:32:36.097389 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10400 - Analysing at 20.00 fps]
2019-01-14 19:32:34.506369 zma_m4[102213].INF-zm_monitor.cpp/1247 [3 - Nursery: 2300 - Analysing at 5.00 fps]
2019-01-14 19:32:33.037889 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:11200 - Capturing at 25.00 fps, capturing bandwidth 295331bytes/sec]
2019-01-14 19:32:32.884003 zmc_m4[102604].INF-zm_monitor.cpp/2477 [3 - Nursery: images:2300 - Capturing at 5.00 fps, capturing bandwidth 13351bytes/sec]
2019-01-14 19:32:32.124632 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:11200 - Capturing at 20.00 fps, capturing bandwidth 228921bytes/sec]
2019-01-14 19:32:31.986168 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10300 - Analysing at 25.00 fps]
2019-01-14 19:32:31.767059 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 10000 - Analysing at 25.00 fps]
2019-01-14 19:32:29.033179 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:11100 - Capturing at 25.00 fps, capturing bandwidth 295021bytes/sec]
2019-01-14 19:32:27.887596 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:11100 - Capturing at 25.00 fps, capturing bandwidth 298612bytes/sec]
2019-01-14 19:32:27.596609 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9900 - Analysing at 20.00 fps]
2019-01-14 19:32:27.542601 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10200 - Analysing at 25.00 fps]
2019-01-14 19:32:25.045355 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:11000 - Capturing at 25.00 fps, capturing bandwidth 284172bytes/sec]
2019-01-14 19:32:23.847233 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:11000 - Capturing at 25.00 fps, capturing bandwidth 297917bytes/sec]
2019-01-14 19:32:23.057280 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10100 - Analysing at 25.00 fps]
2019-01-14 19:32:22.906308 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9800 - Analysing at 25.00 fps]
2019-01-14 19:32:21.046674 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10900 - Capturing at 25.00 fps, capturing bandwidth 276084bytes/sec]
2019-01-14 19:32:19.856688 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10900 - Capturing at 25.00 fps, capturing bandwidth 293429bytes/sec]
2019-01-14 19:32:19.046648 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 10000 - Analysing at 20.00 fps]
2019-01-14 19:32:18.642382 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9700 - Analysing at 25.00 fps]
2019-01-14 19:32:17.086494 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10800 - Capturing at 16.67 fps, capturing bandwidth 178688bytes/sec]
2019-01-14 19:32:15.686119 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10800 - Capturing at 20.00 fps, capturing bandwidth 210320bytes/sec]
2019-01-14 19:32:14.473178 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9900 - Analysing at 16.67 fps]
2019-01-14 19:32:14.300878 zma_m4[102213].INF-zm_monitor.cpp/1247 [3 - Nursery: 2200 - Analysing at 4.76 fps]
2019-01-14 19:32:14.107511 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9600 - Analysing at 16.67 fps]
2019-01-14 19:32:13.086083 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:13.053977 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:13.022474 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:12.996786 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:12.967732 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:12.892591 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:12.859007 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:12.829179 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:12.799068 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:12.662178 zmc_m4[102604].INF-zm_monitor.cpp/2477 [3 - Nursery: images:2200 - Capturing at 5.00 fps, capturing bandwidth 14073bytes/sec]
2019-01-14 19:32:12.568452 zmc_m1[102549].ERR-zm_ffmpeg_camera.cpp/240 [Unable to send packet at frame 10707: Resource temporarily unavailable, continuing]
2019-01-14 19:32:11.641025 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10700 - Capturing at 25.00 fps, capturing bandwidth 293171bytes/sec]
2019-01-14 19:32:10.248583 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10700 - Capturing at 25.00 fps, capturing bandwidth 294194bytes/sec]
2019-01-14 19:32:08.858418 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9800 - Analysing at 25.00 fps]
2019-01-14 19:32:08.575393 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9500 - Analysing at 25.00 fps]
2019-01-14 19:32:07.646745 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10600 - Capturing at 25.00 fps, capturing bandwidth 296947bytes/sec]
2019-01-14 19:32:06.245907 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10600 - Capturing at 25.00 fps, capturing bandwidth 297145bytes/sec]
2019-01-14 19:32:04.774510 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9700 - Analysing at 25.00 fps]
2019-01-14 19:32:04.029431 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9400 - Analysing at 20.00 fps]
2019-01-14 19:32:03.646822 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10500 - Capturing at 25.00 fps, capturing bandwidth 293918bytes/sec]
2019-01-14 19:32:02.246212 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10500 - Capturing at 25.00 fps, capturing bandwidth 297351bytes/sec]
2019-01-14 19:32:00.673965 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9600 - Analysing at 25.00 fps]
2019-01-14 19:31:59.777624 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9300 - Analysing at 25.00 fps]
2019-01-14 19:31:59.646594 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10400 - Capturing at 25.00 fps, capturing bandwidth 297179bytes/sec]
2019-01-14 19:31:58.246516 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10400 - Capturing at 25.00 fps, capturing bandwidth 294458bytes/sec]
2019-01-14 19:31:56.471391 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9500 - Analysing at 25.00 fps]
2019-01-14 19:31:55.648894 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10300 - Capturing at 25.00 fps, capturing bandwidth 297417bytes/sec]
2019-01-14 19:31:55.540401 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9200 - Analysing at 25.00 fps]
2019-01-14 19:31:54.247036 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10300 - Capturing at 25.00 fps, capturing bandwidth 300007bytes/sec]
2019-01-14 19:31:53.921959 zma_m4[102213].INF-zm_monitor.cpp/1247 [3 - Nursery: 2100 - Analysing at 5.00 fps]
2019-01-14 19:31:52.444236 zmc_m4[102604].INF-zm_monitor.cpp/2477 [3 - Nursery: images:2100 - Capturing at 5.00 fps, capturing bandwidth 13252bytes/sec]
2019-01-14 19:31:52.413026 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9400 - Analysing at 25.00 fps]
2019-01-14 19:31:51.646465 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10200 - Capturing at 25.00 fps, capturing bandwidth 295332bytes/sec]
2019-01-14 19:31:51.169340 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9100 - Analysing at 20.00 fps]
2019-01-14 19:31:50.247007 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10200 - Capturing at 25.00 fps, capturing bandwidth 298161bytes/sec]
2019-01-14 19:31:48.502650 zmfilter_2[53386].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-01-14 19:31:48.268423 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9300 - Analysing at 20.00 fps]
2019-01-14 19:31:47.793640 zmfilter_1[53382].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-01-14 19:31:47.647444 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10100 - Capturing at 25.00 fps, capturing bandwidth 290839bytes/sec]
2019-01-14 19:31:46.907314 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 9000 - Analysing at 25.00 fps]
2019-01-14 19:31:46.247107 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10100 - Capturing at 25.00 fps, capturing bandwidth 297350bytes/sec]
2019-01-14 19:31:43.924955 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9200 - Analysing at 25.00 fps]
2019-01-14 19:31:43.581968 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:10000 - Capturing at 20.00 fps, capturing bandwidth 223501bytes/sec]
2019-01-14 19:31:42.512001 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8900 - Analysing at 20.00 fps]
2019-01-14 19:31:42.247944 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:10000 - Capturing at 25.00 fps, capturing bandwidth 297979bytes/sec]
2019-01-14 19:31:39.433391 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9100 - Analysing at 25.00 fps]
2019-01-14 19:31:38.618117 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9900 - Capturing at 25.00 fps, capturing bandwidth 280103bytes/sec]
2019-01-14 19:31:38.247732 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9900 - Capturing at 25.00 fps, capturing bandwidth 298835bytes/sec]
2019-01-14 19:31:37.238998 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8800 - Analysing at 20.00 fps]
2019-01-14 19:31:35.317390 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 9000 - Analysing at 25.00 fps]
2019-01-14 19:31:34.623894 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9800 - Capturing at 25.00 fps, capturing bandwidth 282454bytes/sec]
2019-01-14 19:31:34.247997 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9800 - Capturing at 25.00 fps, capturing bandwidth 297821bytes/sec]
2019-01-14 19:31:33.713869 zma_m4[102213].INF-zm_monitor.cpp/1247 [3 - Nursery: 2000 - Analysing at 5.00 fps]
2019-01-14 19:31:32.752330 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8700 - Analysing at 20.00 fps]
2019-01-14 19:31:32.209670 zmc_m4[102604].INF-zm_monitor.cpp/2477 [3 - Nursery: images:2000 - Capturing at 4.76 fps, capturing bandwidth 12687bytes/sec]
2019-01-14 19:31:31.251436 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8900 - Analysing at 25.00 fps]
2019-01-14 19:31:30.606592 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9700 - Capturing at 25.00 fps, capturing bandwidth 270040bytes/sec]
2019-01-14 19:31:30.248498 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9700 - Capturing at 25.00 fps, capturing bandwidth 297531bytes/sec]
2019-01-14 19:31:27.907400 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8600 - Analysing at 25.00 fps]
2019-01-14 19:31:27.139376 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8800 - Analysing at 25.00 fps]
2019-01-14 19:31:26.434469 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9600 - Capturing at 25.00 fps, capturing bandwidth 291575bytes/sec]
2019-01-14 19:31:26.248546 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9600 - Capturing at 25.00 fps, capturing bandwidth 297189bytes/sec]
2019-01-14 19:31:23.642204 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8500 - Analysing at 25.00 fps]
2019-01-14 19:31:23.040337 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8700 - Analysing at 20.00 fps]
2019-01-14 19:31:22.261067 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9500 - Capturing at 25.00 fps, capturing bandwidth 281043bytes/sec]
2019-01-14 19:31:22.248322 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9500 - Capturing at 25.00 fps, capturing bandwidth 297534bytes/sec]
2019-01-14 19:31:19.458349 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8400 - Analysing at 25.00 fps]
2019-01-14 19:31:18.991395 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8600 - Analysing at 25.00 fps]
2019-01-14 19:31:18.249157 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9400 - Capturing at 25.00 fps, capturing bandwidth 288487bytes/sec]
2019-01-14 19:31:18.141652 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9400 - Capturing at 25.00 fps, capturing bandwidth 300002bytes/sec]
2019-01-14 19:31:15.016685 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8300 - Analysing at 20.00 fps]
2019-01-14 19:31:14.887597 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8500 - Analysing at 25.00 fps]
2019-01-14 19:31:14.236823 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9300 - Capturing at 20.00 fps, capturing bandwidth 224841bytes/sec]
2019-01-14 19:31:14.145040 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9300 - Capturing at 20.00 fps, capturing bandwidth 223200bytes/sec]
2019-01-14 19:31:13.486397 zma_m4[102213].INF-zm_monitor.cpp/1247 [3 - Nursery: 1900 - Analysing at 5.00 fps]
2019-01-14 19:31:11.990633 zmc_m4[102604].INF-zm_monitor.cpp/2477 [3 - Nursery: images:1900 - Capturing at 5.00 fps, capturing bandwidth 14076bytes/sec]
2019-01-14 19:31:10.580524 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8200 - Analysing at 25.00 fps]
2019-01-14 19:31:10.360415 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8400 - Analysing at 20.00 fps]
2019-01-14 19:31:09.781978 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9200 - Capturing at 25.00 fps, capturing bandwidth 311476bytes/sec]
2019-01-14 19:31:09.709572 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9200 - Capturing at 25.00 fps, capturing bandwidth 299160bytes/sec]
2019-01-14 19:31:06.022858 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8100 - Analysing at 20.00 fps]
2019-01-14 19:31:05.863839 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8300 - Analysing at 25.00 fps]
2019-01-14 19:31:05.821021 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9100 - Capturing at 25.00 fps, capturing bandwidth 314932bytes/sec]
2019-01-14 19:31:05.712161 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9100 - Capturing at 25.00 fps, capturing bandwidth 298493bytes/sec]
2019-01-14 19:31:01.823539 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:9000 - Capturing at 25.00 fps, capturing bandwidth 301731bytes/sec]
2019-01-14 19:31:01.765681 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 8000 - Analysing at 25.00 fps]
2019-01-14 19:31:01.733396 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8200 - Analysing at 25.00 fps]
2019-01-14 19:31:01.713596 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:9000 - Capturing at 25.00 fps, capturing bandwidth 295980bytes/sec]
2019-01-14 19:30:57.857588 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8900 - Capturing at 25.00 fps, capturing bandwidth 294716bytes/sec]
2019-01-14 19:30:57.753191 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8900 - Capturing at 25.00 fps, capturing bandwidth 297843bytes/sec]
2019-01-14 19:30:57.660170 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8100 - Analysing at 25.00 fps]
2019-01-14 19:30:57.621019 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7900 - Analysing at 25.00 fps]
2019-01-14 19:30:53.861450 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8800 - Capturing at 25.00 fps, capturing bandwidth 299808bytes/sec]
2019-01-14 19:30:53.721853 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8800 - Capturing at 25.00 fps, capturing bandwidth 309427bytes/sec]
2019-01-14 19:30:53.555438 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 8000 - Analysing at 25.00 fps]
2019-01-14 19:30:53.438549 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7800 - Analysing at 25.00 fps]
2019-01-14 19:30:53.251827 zma_m4[102213].INF-zm_monitor.cpp/1247 [3 - Nursery: 1800 - Analysing at 4.76 fps]
2019-01-14 19:30:51.771725 zmc_m4[102604].INF-zm_monitor.cpp/2477 [3 - Nursery: images:1800 - Capturing at 5.00 fps, capturing bandwidth 13098bytes/sec]
2019-01-14 19:30:49.866211 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8700 - Capturing at 25.00 fps, capturing bandwidth 302477bytes/sec]
2019-01-14 19:30:49.691876 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8700 - Capturing at 25.00 fps, capturing bandwidth 330843bytes/sec]
2019-01-14 19:30:49.400264 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7900 - Analysing at 20.00 fps]
2019-01-14 19:30:49.026445 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7700 - Analysing at 16.67 fps]
2019-01-14 19:30:48.547415 web_js[50730].ERR-?view=log [Export request failed: 500 / Internal Server Error - exportFail()]
2019-01-14 19:30:48.273770 zmfilter_2[53386].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 5 events ]
2019-01-14 19:30:47.916513 zma_m1[100819].INF-zm_monitor.cpp/1647 [1 - Front Door: 7678 - Closing event 1233, alarm end]
2019-01-14 19:30:47.895053 zma_m1[100819].INF-zm_monitor.cpp/1643 [1 - Front Door: 7678 - Left alarm state (1233) - 10(5) images]
2019-01-14 19:30:47.753780 zmfilter_1[53382].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-01-14 19:30:47.651395 zma_m1[100819].INF-zm_monitor.cpp/1639 [1 - Front Door: 7673 - Gone into alert state]
2019-01-14 19:30:47.426246 zma_m3[100932].INF-zm_monitor.cpp/1647 [2 - Front House: 7857 - Closing event 1232, alarm end]
2019-01-14 19:30:47.402828 zma_m3[100932].INF-zm_monitor.cpp/1643 [2 - Front House: 7857 - Left alarm state (1232) - 11(6) images]
2019-01-14 19:30:47.137380 zma_m3[100932].INF-zm_monitor.cpp/1639 [2 - Front House: 7852 - Gone into alert state]
2019-01-14 19:30:47.061708 zma_m1[100819].INF-zm_monitor.cpp/1606 [1 - Front Door: 7668 - Opening new event 1233, alarm start]
2019-01-14 19:30:46.996590 zma_m1[100819].INF-zm_monitor.cpp/1544 [1 - Front Door: 7668 - Gone into alarm state PreAlarmCount: 0 > AlarmFrameCount:1]
2019-01-14 19:30:46.583040 zma_m3[100932].INF-zm_monitor.cpp/1606 [2 - Front House: 7846 - Opening new event 1232, alarm start]
2019-01-14 19:30:46.284163 zma_m3[100932].INF-zm_monitor.cpp/1544 [2 - Front House: 7846 - Gone into alarm state PreAlarmCount: 0 > AlarmFrameCount:1]
2019-01-14 19:30:45.712799 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8600 - Capturing at 25.00 fps, capturing bandwidth 319497bytes/sec]
2019-01-14 19:30:45.573194 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8600 - Capturing at 25.00 fps, capturing bandwidth 326828bytes/sec]
2019-01-14 19:30:44.314398 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7800 - Analysing at 20.00 fps]
2019-01-14 19:30:43.727721 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7600 - Analysing at 25.00 fps]
2019-01-14 19:30:41.575028 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8500 - Capturing at 20.00 fps, capturing bandwidth 244383bytes/sec]
2019-01-14 19:30:41.171564 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8500 - Capturing at 20.00 fps, capturing bandwidth 230911bytes/sec]
2019-01-14 19:30:39.520762 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7700 - Analysing at 20.00 fps]
2019-01-14 19:30:39.318715 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7500 - Analysing at 16.67 fps]
2019-01-14 19:30:36.266986 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8400 - Capturing at 25.00 fps, capturing bandwidth 289060bytes/sec]
2019-01-14 19:30:36.181200 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8400 - Capturing at 25.00 fps, capturing bandwidth 288613bytes/sec]
2019-01-14 19:30:34.223398 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7600 - Analysing at 25.00 fps]
2019-01-14 19:30:33.746397 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7400 - Analysing at 25.00 fps]
2019-01-14 19:30:32.990583 zma_m4[102213].INF-zm_monitor.cpp/1247 [3 - Nursery: 1700 - Analysing at 5.00 fps]
2019-01-14 19:30:32.258234 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8300 - Capturing at 25.00 fps, capturing bandwidth 287364bytes/sec]
2019-01-14 19:30:32.181251 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8300 - Capturing at 25.00 fps, capturing bandwidth 289585bytes/sec]
2019-01-14 19:30:31.519173 zmc_m4[102604].INF-zm_monitor.cpp/2477 [3 - Nursery: images:1700 - Capturing at 5.00 fps, capturing bandwidth 13236bytes/sec]
2019-01-14 19:30:30.093959 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7500 - Analysing at 20.00 fps]
2019-01-14 19:30:29.524866 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7300 - Analysing at 20.00 fps]
2019-01-14 19:30:28.269425 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8200 - Capturing at 25.00 fps, capturing bandwidth 287061bytes/sec]
2019-01-14 19:30:28.172044 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8200 - Capturing at 25.00 fps, capturing bandwidth 287728bytes/sec]
2019-01-14 19:30:25.952417 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7400 - Analysing at 25.00 fps]
2019-01-14 19:30:24.647324 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7200 - Analysing at 20.00 fps]
2019-01-14 19:30:24.172405 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8100 - Capturing at 25.00 fps, capturing bandwidth 291878bytes/sec]
2019-01-14 19:30:24.019085 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8100 - Capturing at 20.00 fps, capturing bandwidth 228554bytes/sec]
2019-01-14 19:30:23.364593 web_js[49794].ERR-?view=log [Export request failed: 500 / Internal Server Error - exportFail()]
2019-01-14 19:30:21.869929 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7300 - Analysing at 25.00 fps]
2019-01-14 19:30:20.181209 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:8000 - Capturing at 25.00 fps, capturing bandwidth 328429bytes/sec]
2019-01-14 19:30:20.018708 zma_m1[100819].INF-zm_monitor.cpp/1647 [1 - Front Door: 7101 - Closing event 1231, alarm end]
2019-01-14 19:30:19.904087 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:8000 - Capturing at 25.00 fps, capturing bandwidth 347451bytes/sec]
2019-01-14 19:30:19.785648 zma_m1[100819].INF-zm_monitor.cpp/1643 [1 - Front Door: 7101 - Left alarm state (1231) - 22(17) images]
2019-01-14 19:30:19.536611 zma_m1[100819].INF-zm_monitor.cpp/1247 [1 - Front Door: 7100 - Analysing at 12.50 fps]
2019-01-14 19:30:19.336622 zma_m1[100819].INF-zm_monitor.cpp/1639 [1 - Front Door: 7096 - Gone into alert state]
2019-01-14 19:30:17.831716 zma_m1[100819].INF-zm_monitor.cpp/1606 [1 - Front Door: 7079 - Opening new event 1231, alarm start]
2019-01-14 19:30:17.790819 zma_m1[100819].INF-zm_monitor.cpp/1544 [1 - Front Door: 7079 - Gone into alarm state PreAlarmCount: 0 > AlarmFrameCount:1]
2019-01-14 19:30:17.762392 zma_m3[100932].INF-zm_monitor.cpp/1247 [2 - Front House: 7200 - Analysing at 14.29 fps]
2019-01-14 19:30:17.307257 zma_m1[100819].INF-zm_monitor.cpp/1647 [1 - Front Door: 7078 - Closing event 1230, alarm end]
2019-01-14 19:30:17.282761 zma_m1[100819].INF-zm_monitor.cpp/1643 [1 - Front Door: 7078 - Left alarm state (1230) - 35(30) images]
2019-01-14 19:30:17.038103 zma_m1[100819].INF-zm_monitor.cpp/1639 [1 - Front Door: 7073 - Gone into alert state]
2019-01-14 19:30:16.394923 zma_m3[100932].INF-zm_monitor.cpp/1647 [2 - Front House: 7180 - Closing event 1229, alarm end]
2019-01-14 19:30:16.380155 zma_m3[100932].INF-zm_monitor.cpp/1643 [2 - Front House: 7180 - Left alarm state (1229) - 35(30) images]
2019-01-14 19:30:16.176681 zmc_m3[100812].INF-zm_monitor.cpp/2477 [2 - Front House: images:7900 - Capturing at 25.00 fps, capturing bandwidth 347931bytes/sec]
2019-01-14 19:30:16.071347 zma_m3[100932].INF-zm_monitor.cpp/1639 [2 - Front House: 7175 - Gone into alert state]
2019-01-14 19:30:15.904767 zmc_m1[102549].INF-zm_monitor.cpp/2477 [1 - Front Door: images:7900 - Capturing at 25.00 fps, capturing bandwidth 357488bytes/sec]
2019-01-14 19:30:15.303896 zmc_m1[102549].WAR-zm_monitor.cpp/2441 [Buffer overrun at index 4, image 7884, slow down capture, speed up analysis or increase ring buffer size]
2019-01-14 19:30:15.293477 zmc_m3[100812].WAR-zm_monitor.cpp/2441 [Buffer overrun at index 17, image 7877, slow down capture, speed up analysis or increase ring buffer size]
2019-01-14 19:30:15.230057 zmc_m1[102549].WAR-zm_monitor.cpp/2441 [Buffer overrun at index 2, image 7882, slow down capture, speed up analysis or increase ring buffer size]
Camera Config
Thank you very much indeed.
Leigh
28061
Re: Recording problem, distorted picture, log file export problem
Post by 28061 » Tue Jan 15, 2019 8:46 am
Adding another issue!
I can't access my system from ZmNinja.
Auth_Type=builtin
Opt_Use_Auth=Enabled
Auth_Hash_Logins=Enabled
Opt_Use_Api=Enabled
Browsing to /zm/api/host/getVersion.json; regardless of above settings gives me this
Warning (2): mkdir(): Permission denied [CORE/Cake/Log/Engine/FileLog.php, line 106]
Warning (2): mkdir() [<a href='http://php.net/function.mkdir'>function.mkdir</a>]: Permission denied [CORE/Cake/Log/Engine/FileLog.php, line 106]
Warning (2): ini_set() [<a href='http://php.net/function.ini-set'>function.ini-set</a>]: Headers already sent. You cannot change the session module's ini settings at this time [CORE/Cake/Model/Datasource/CakeSession.php, line 581]
Warning (2): file_put_contents(/var/log/zm/cake_error.log) [<a href='http://php.net/function.file-put-contents'>function.file-put-contents</a>]: failed to open stream: No such file or directory [CORE/Cake/Log/Engine/FileLog.php, line 142]
Warning (2): file_put_contents(/var/log/zm/error.log) [<a href='http://php.net/function.file-put-contents'>function.file-put-contents</a>]: failed to open stream: No such file or directory [CORE/Cake/Log/Engine/FileLog.php, line 142]
Warning (2): ini_set() [<a href='http://php.net/function.ini-set'>function.ini-set</a>]: Headers already sent. You cannot change the session module's ini settings at this time [CORE/Cake/Model/Datasource/CakeSession.php, line 581]{ "success": false, "data": { "code": 500, "name": "Unable to configure the session, setting session.use_trans_sid failed.", "message": "Unable to configure the session, setting session.use_trans_sid failed.", "url": "\/zm\/api\/host\/getVersion.json?p=%2Fhost%2FgetVersion.json", "exception": { "class": "CakeSessionException", "code": 500, "message": "Unable to configure the session, setting session.use_trans_sid failed.", "trace": [ "#0 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Model\/Datasource\/CakeSession.php(619): CakeSession::_configureSession()", "#1 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Model\/Datasource\/CakeSession.php(632): CakeSession::_cookieName()", "#2 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Model\/Datasource\/CakeSession.php(404): CakeSession::_hasSession()", "#3 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Controller\/Component\/SessionComponent.php(69): CakeSession::read('user')", "#4 \/usr\/local\/www\/zoneminder\/api\/app\/Controller\/AppController.php(70): SessionComponent->read('user')", "#5 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Event\/CakeEventManager.php(243): AppController->beforeFilter(Object(CakeEvent))", "#6 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Controller\/Controller.php(677): CakeEventManager->dispatch(Object(CakeEvent))", "#7 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Routing\/Dispatcher.php(189): Controller->startupProcess()", "#8 \/usr\/local\/www\/zoneminder\/api\/lib\/Cake\/Routing\/Dispatcher.php(167): Dispatcher->_invoke(Object(HostController), Object(CakeRequest))", "#9 \/usr\/local\/www\/zoneminder\/api\/app\/webroot\/index.php(107): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))", "#10 {main}" ] }, "queryLog": [] } }
bermau13
Post by bermau13 » Tue Jan 29, 2019 8:14 pm
hi,
i have the save issue, have you solved your problem with zmninja?
my installation: freenas plugin 11.2 - zoneminder 1.32.2
Users browsing this forum: No registered users and 6 guests
