Ffmpeg stream stopped working after update to 1.32.3
jHeron
Post by jHeron » Sun Jan 06, 2019 4:32 pm
Fedora 29_64
Zoneminder 1.32.3 (from fed repos)
I have an EasyN IP cam that was working fine until ZM upgraded without me noticing to 1.32.3.
Source type = Ffmpeg
source path = RTSP://admin:pass@192.168.1.94:554/11
method = TCP
Storage:
Save JPEGs = Disabled
Video writer = H264 passthrough or X264 encode both same effect, no video.
I tried the ONIF probe and it detected the same settings with no joy.
The LOG says:
unable to open input PATH due to: connection reset by peer
Any suggestion on how to get this thing recording again would be appreciated!
Cheers,
Jon
Re: Ffmpeg stream stopped working after update to 1.32.3
Post by bbunge » Sun Jan 06, 2019 8:06 pm
You may have to upgrade the database manually.
jHeron
Post by jHeron » Sun Jan 06, 2019 9:39 pm
I did run a zmupdate.pl
Is that what you mean?
Cheers,
Jon
