Problem with analysis images
kkrofft
Post by kkrofft » Thu Jan 03, 2019 2:43 am
Running ZM 1.32.3 on CentOS 7.5 and trying to fine tune my motion detection. I am getting a large number of false positives where I cannot discern
any motion from the playback. I would like to turn on "analysis frame" creation and have checked the box on the Options>Config screen and saved but none of the monitors show any analysis frames when stepping through the event frames. Tried unchecking the box with the same result.
Is "CREATE_ANALYSIS_IMAGES" working in 1.32.3? How can I troubleshoot this?
Thank you for your suggestions.
Kory
SkippyDo
Re: Problem with analysis images
Post by SkippyDo » Fri Jan 04, 2019 9:48 am
Yeah, on Debian 9 I'm also seeming to be missing this ability (though I have CREATE_ANALYSIS_IMAGES enabled).
kkrofft
Post by kkrofft » Fri Jan 04, 2019 2:15 pm
OK. So maybe not just me. Anyone else?
Post by knight-of-ni » Sat Jan 05, 2019 12:33 am
Open Monitor Config -> Storage tab -> Enable Analysis Image jpegs
Your motion zones also need to have the Blob method enabled.
SkippyDo
Post by SkippyDo » Sat Jan 05, 2019 2:10 am
Thanks!
kkrofft
Post by kkrofft » Sat Jan 05, 2019 3:35 am
Yup, that did the trick. Would be good to add that to the pop-up help for Create_Aanalysis_Images. I would be happy to add it if I knew how to get it in there. Say perhaps:
Note:To enable creation of analysis images, set Save JPEGs to Analysis images only or to Frames + Analysis images on the Storage tab of Monitor Definition (Source).
Or I suppose the code could be updated to override the Save JPEGs setting behind the scenes when the Create_Analysis_Images box is checked.
Anyway, thanks for the tip.
Post by knight-of-ni » Sat Jan 05, 2019 1:53 pm
CREATE_ANALYSIS_IMAGES will not not be present in the next release.
This is a work in progress while we transition from jpeg -> mp4 so some things overlap at the moment.
Tomm
Post by Tomm » Tue Feb 12, 2019 11:43 am
Does that mean we won't be able to see the analysis frames when trying to tune the zones ?
Post by knight-of-ni » Tue Feb 12, 2019 1:24 pm
No. It means the setting is per camera rather than global.
