Howdy all!
I'm hoping that someone has accomplished this, or if they haven't hoping that @asker or @iconnor can help me out here.
I'd basically like to be able to reference a ZoneMinder monitor within a Grafana dashboard. I'd basically like to emulate what zmNinja does, but for the web. The reasoning behind this is because I have a display that sits on a wall and constantly flips between 3 displays (related to the hardware environment). If I were able to display the ZoneMinder monitors as part of the Grafana dashboard, then I could also have an always-on display of my ZoneMinder cameras as well...
I tried using a simple Grafana "Text" panel in HTML mode, and used the direct image address of a monitor (from view source), but I couldn't figure out dynamic resizing (I want it to auto-fit to the panel size), and I'm sure that the login info would eventually time-out and I'd need to do something to refresh it.
Any help would be appreciated.
Setting up a zmNinja-like dashboard using Grafana?
Re: Setting up a zmNinja-like dashboard using Grafana?
Sure.
1. If you use "&user=xxx&pass=" instead of "&auth=" in your URL, the auth will never expire. The downsides are more frequent DB dips and password in clear text. But this is least complicated
2. If you use "&auth=" just keep using the "login.json" API once every hour to refresh the credentials (and use the returned credential value)
3. As far as fitting windows into the screen is concerned, it is a CSS issue and easily solved. Google for it. There are many approaches. Here is one
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Thanks!! Given that this is a local instance, I created a user that can only view, so it works like a charm. I might look into the auth piece later, but this was a clean drop-in fix.
'Doh! I was trying to wrap them in an iframe because that's what the grafana tutorial recommended. As soon as I dropped that and just used a simple img tag, it worked immediately also.
Now... Is there an EASY way to fix the concurrent connection limit? I have 9 cameras and I believe this will only allow 6 at a time.
Switch to ZM's multi-port support. Will work on all browsers.jsylvia007 wrote: ↑Fri Jan 04, 2019 2:25 pm Now... Is there an EASY way to fix the concurrent connection limit? I have 9 cameras and I believe this will only allow 6 at a time.
For an easier way, switch to Firefox - I believe it has a setting to increase it (you'll have to google for it)
ES docs
zmNinja docs
ES docs
zmNinja docs
Well that wasn't nearly as scary as I thought it would be either... Wow. Thanks!asker wrote: ↑Fri Jan 04, 2019 2:42 pmSwitch to ZM's multi-port support. Will work on all browsers.jsylvia007 wrote: ↑Fri Jan 04, 2019 2:25 pm Now... Is there an EASY way to fix the concurrent connection limit? I have 9 cameras and I believe this will only allow 6 at a time.
