ive been doing some tests trying to get one of my camera to ignore bright lights and ive noticed that if i set an active zone with a 15 threshold and a 100 alarmed 100 filtered and 2 blobs it never detects anything..
can blobs be by themselves?
it appears that filtered isnt working either.. maybe my other issue is combined with this one.
are blobs working in 1.32.3?
Re: are blobs working in 1.32.3?
No, Blob method is a progressive detection algorithm.can blobs be by themselves?
Threshold then Area, Filtered Area then Blobs.
https://wiki.zoneminder.com/Understandi ... or_Dummies
https://zoneminder.readthedocs.io/en/st ... ezone.html
Yesare blobs working in 1.32.3
ok but the problem is in my testing, the alarmed pixels are setting off the trigger, way before the blobs and if you have them set to higher then nothing gets triggered.Pedulla wrote: ↑Sat Dec 15, 2018 1:54 amNo, Blob method is a progressive detection algorithm.can blobs be by themselves?
try it out, set the alarmed pixels to like 80 and blobs to 2.
