The screenshot shows that 2 storage resources in the load line (Default 12% / Default 82%) however when viewing storage resources in options it is not visible. I'm afraid to add/define it since I have all my video data on the second storage (12TB worth).
Any ideas on what is going on. Running Centos 7.
Image link:
https://photos.app.goo.gl/HX1qifR1ArAxkVUA8
Storage resources not listed properly
Re: Storage resources not listed properly
I had this happen to myself, early on in 1.32 testing. Here's what I did: First off, Default is listed in the storage spaces. So, I deleted that, then I made myself a new Default, with an external HDD. Come back to the main screen, and there are two Defaults listed... I simply deleted the new default, and added a new storage space, with a different name. At this point, storage space lists only the new entry, yet the console has Default, and the "NewName". Which is OK with me.
I'm not sure that is what happened to you, but it does explain how 2 defaults were able to be created for storage spaces. Even if you delete the old default, it still remains on the console screen, if I recall right.
