Confused about login settings
mn1247
Post by mn1247 »
I have a ZM 1.32 server running on Ubuntu Server 18 with Apache 2. All traffic is through HTTPS/SSL. I access ZM via either web browsers or zmninja.
My question pertains to setting up the login mode for ZM. I have OPT_USE_AUTH enabled and the AUTH_TYPE is "built-in". I've been unable to enable hashed relays (no video), but zmninja complains (error message) if I disable this (even though video gets through). Given, SSL, I'm wondering why I would need hashed relays anyway.
Any advice on this?
Eric
Re: Confused about login settings
I have used AUTH_RELAY = none for so long I have forgotten why. Use just a basic login.
If you want extra security use OPT_USE_GOOG_RECAPTCHA
