Can't access web interface
Posted: Sun Nov 25, 2018 6:41 pm
Hi!
I'm a newbe on both Linux and Zoneminder.
I've installed Centos 7 and Zoneminder a week ago, following different installation guides
ex.
http://buney.net/index.php/2018/01/07/h ... k-summary/
and
https://zoneminder.readthedocs.io/en/la ... edhat.html
But every time i get the same result, Error message "The webpage can't be showen", when trying to access the web interface.
I use the link
https://192.168.176.7/zm
I would really appreciate if you would give me an ide of what the problem could be
Zoneminder status
[root@localhost fredrik]# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and security system
Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; enabled; vendor preset: disabled)
Active: active (running) since sön 2018-11-18 21:36:03 CET; 6 days ago
Process: 12301 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 12318 (zmdc.pl)
CGroup: /system.slice/zoneminder.service
├─12318 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
├─12347 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
├─12359 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
├─12374 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
├─12390 /usr/bin/perl -wT /usr/bin/zmwatch.pl
└─12404 /usr/bin/perl -wT /usr/bin/zmstats.pl
nov 25 19:19:25 localhost.localdomain zmfilter_1[12347]: INF [Checking filter PurgeWhenFull del... ]
nov 25 19:19:37 localhost.localdomain zmfilter_2[12359]: INF [Checking filter Update DiskSpace ... ]
nov 25 19:20:25 localhost.localdomain zmfilter_1[12347]: INF [Checking filter PurgeWhenFull del... ]
nov 25 19:20:37 localhost.localdomain zmfilter_2[12359]: INF [Checking filter Update DiskSpace ... ]
nov 25 19:21:11 localhost.localdomain zmaudit[12374]: INF [Auditing All Storage Areas]
nov 25 19:21:11 localhost.localdomain zmaudit[12374]: INF [Deleted 0 log table entries by time]
nov 25 19:21:25 localhost.localdomain zmfilter_1[12347]: INF [Checking filter PurgeWhenFull del... ]
nov 25 19:21:37 localhost.localdomain zmfilter_2[12359]: INF [Checking filter Update DiskSpace ... ]
nov 25 19:22:25 localhost.localdomain zmfilter_1[12347]: INF [Checking filter PurgeWhenFull del... ]
nov 25 19:22:37 localhost.localdomain zmfilter_2[12359]: INF [Checking filter Update DiskSpace ... ]
Hint: Some lines were ellipsized, use -l to show in full.
ex.
and
I use the link
Zoneminder status
