New user, camera not showing up.
Posted: Sat Nov 24, 2018 10:44 am
I have a camera that I am able to view in VLC and an ONVIF viewer without problem. When I try to add the camera to a new installation (via docker) of ZoneMinder the camera shows up as Not Running.
Details about the camera from ONVIF tool:
Details from VLC:
The camera URL is of the form:
I have done my best to fill in the monitor add dialog with information that matches what ONVIF tool and VLC present, but nothing seems to make the camera show up in ZoneMinder.
ZoneMinder settings:
I have tried looking at the logs, and I do see some errors and warnings but none of it gives me any hints as to what the problem might be, the following logs repeat over and over:
Looking at the above, is there anything that is obviously wrong with my setup attempt? Is H-265 supported out of the box with the docker image found here: https://github.com/ZoneMinder/zmdockerf ... Dockerfile ? What can I do to further troubleshoot?
Type: RTSP
Frame Rate (fps): 30
Data Rate (Mbit/s): 0.686
Resolution: 1920x1080
Encoding: H265
Transport protocol: TCP
RTSP handshake time (s): .5
Codec: MPEG-H Part2/HEVC (H.265) (hevc)
Type: Video
Video Resolution: 1920x1080
Buffer dimensions: 1920x1080
Frame rate: 30
Decoded format:
Orientation: Top left
Color primaries: ITU-R BT.709
Color transfer function: ITU-R BT.709
Color space: ITU-R BT.709 Range
rtsp://<user>:<pass>@<ip>:<port>/unicast/c1/s0/live
Server: None
Storage Area: Default
Source Type: ffmpeg
Function: Monitor
Enabled: true
Maximum FPS: 30.00
Alarm Maximum FPS: 30.00
Source Path: rtsp://<user>:<pass>@<ip>:<port>/unicast/c1/s0/live
Method: TCP
Target Colorspace: 32 bit colour
Capture Width: 1920
Capture Height: 1080
2018-11-24 18:43:17 zmwatch 366 INF Restarting capture daemon for Entry, shared data not valid zmwatch.pl
2018-11-24 18:43:07 zmwatch 366 INF Restarting capture daemon for Entry, shared data not valid zmwatch.pl
2018-11-24 18:43:07 zmdc 308 INF Command 'zmc -m 1' removed from pending list at 18/11/24 18:43:07 zmdc.pl
2018-11-24 18:43:06 zmdc 308 INF 'zmc -m 1' crashed, signal 6 zmdc.pl
2018-11-24 18:43:05 zmdc 308 INF Starting pending process, zmc -m 1 zmdc.pl
2018-11-24 18:43:05 zmdc 308 INF 'zmc -m 1' starting at 18/11/24 18:43:05, pid = 3531 zmdc.pl
2018-11-24 18:43:05 zmdc 3531 INF 'zmc -m 1' started at 18/11/24 18:43:05 zmdc.pl
2018-11-24 18:43:00 zmdc 308 INF 'zmc -m 1' crashed, signal 6 zmdc.pl
2018-11-24 18:42:59 zmdc 3520 INF 'zmc -m 1' started at 18/11/24 18:42:59 zmdc.pl
2018-11-24 18:42:59 zmdc 308 INF 'zmc -m 1' starting at 18/11/24 18:42:59, pid = 3520 zmdc.pl
2018-11-24 18:42:59 zmdc 308 INF Starting pending process, zmc -m 1 zmdc.pl
2018-11-24 18:42:58 zmdc 308 INF 'zmc -m 1' crashed, signal 6 zmdc.pl
2018-11-24 18:42:57 zmdc 3514 INF 'zmc -m 1' started at 18/11/24 18:42:57 zmdc.pl
2018-11-24 18:42:57 zmdc 308 INF 'zmc -m 1' starting at 18/11/24 18:42:57, pid = 3514 zmdc.pl
2018-11-24 18:42:57 zmdc 308 WAR Can't find process with command of 'zmc -m 1' zmdc.pl
