Duplicated files/folders
jack52251
Post by jack52251 » Wed Nov 21, 2018 12:17 am
Hi All,
I have an issue with ZM. I installed a fresh docker container under unraid, configured my 5 cameras (DLink) and they all work fine. The issue is that under the data folder, it lists folders 1-5 and then a folder for each of the cameras. When there is an event, it saves .jpg files to both locations. I tried the video option, but the video is very wonky for me and I end up with a video that is unusable, so I went back to .jpgs.
Here is a picture:
mikb
Re: Duplicated files/folders
Post by mikb » Wed Nov 21, 2018 5:21 pm
It's not really in both locations -- if you look closely you should see that the numbered directories are real, and the "named" directories are symbolic links to them (for convenience/user friendly use).
You may find the same if you start poking about inside the directories, a folder called ".12345678" (enable viewing all files including dot files) is a symbolic link to another folder with the hh/mm/ss of the event, e.g. 16/02/24 ...
On console "ls -la" shows ...
drwxr-xr-x  3 apache apache 4096 Jan  8  2018 10/
drwxr-xr-x  3 apache apache 4096 Jan  8  2018 4/
drwxr-xr-x  3 apache apache 4096 Jan  8  2018 5/
drwxr-xr-x  3 apache apache 4096 Jun 13 16:59 6/
drwxr-xr-x  3 apache apache 4096 Jan  8  2018 7/
drwxr-xr-x  3 apache apache 4096 Jan  8  2018 8/
lrwxrwxrwx  1 apache apache    1 Mar 25  2013 CAM01_FRONT_CZ -> 5/
lrwxrwxrwx  1 apache apache    1 Mar 28  2013 CAM02_FRONT_RW -> 4/
lrwxrwxrwx  1 apache apache    1 Mar 24  2013 CAM03_FRONT_LW -> 6/
lrwxrwxrwx  1 apache apache    1 Mar 24  2013 CAM04_REAR_CW -> 7/
lrwxrwxrwx  1 apache apache    1 Mar 24  2013 CAM05_FRONT_GW -> 8/
lrwxrwxrwx  1 apache apache    2 Jun  6  2014 CAM07_REAR_RW -> 10/
jack52251
Post by jack52251 » Wed Nov 21, 2018 6:51 pm
Got it now, thanks for the explanation!
Users browsing this forum: No registered users and 5 guests
