Installed a few weeks ago, failed to notice recordings weren't saving...
raydude
Post by raydude » Sat Nov 17, 2018 4:43 pm
I upgraded my gentoo server to 1.32.2 a few weeks ago thanks to a bunch of folks in the gentoo forums who worked out various ebuild and mariadb issues.
But I didn't notice at the time that the recordings were not being stored.
I'm getting this warning:
Cannot write to content dirs('/var/lib/zoneminder/events','/var/lib/zoneminder/images'). Check that these exist and are owned by the web account user
/etc/zm.conf is in the apache group.
zm.conf points to a completely different directory for storing the events:
snip...
# Path to installed data directory, used mostly for finding DB upgrade scripts
ZM_PATH_DATA=/usr/share/zoneminder
# Path to ZoneMinder binaries
ZM_PATH_BIN=/usr/bin
# Path to ZoneMinder libraries (none at present, for future use)
ZM_PATH_LIB=/usr/lib64
# Path to ZoneMinder configuration (this file only at present)
ZM_PATH_CONF=/etc
# Path to ZoneMinder web files
ZM_PATH_WEB=/usr/share/zoneminder/www
ZM_PATH_CONF=/etc
snip...
And the permissions on those folders are correct also...
I checked the settings in the gui and there was indeed a stoage folder specified as /var/lib/zoneminder/events, and I changed it to /usr/share/zoneminder/www/events, but restarting zoneminder didn't make the message go away.
What am I doing wrong this time?
Thanks in advance.
raydude
Re: Installed a few weeks ago, failed to notice recordings weren't saving...
Post by raydude » Sat Nov 17, 2018 5:07 pm
This looks important... It happens every few minutes. Deleting the pid file does not help.
2018-11-17 09:01:45 zmaudit 14444 FAT zmaudit.pl appears to already be running at pid 10787. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option. zmaudit.pl
2018-11-17 09:01:45 zmdc 14151 ERR 'zmaudit.pl -c' exited abnormally, exit status 255 zmdc.pl
2018-11-17 09:01:45 zmdc 14151 ERR 'zmfilter.pl --filter_id=2 --daemon' exited abnormally, exit status 9 zmdc.pl
2018-11-17 09:01:45 zmdc 14151 ERR 'zmfilter.pl --filter_id=1 --daemon' exited abnormally, exit status 9 zmdc.pl
raydude
Post by raydude » Sat Nov 17, 2018 5:10 pm
Okay. The recordings are there. For some reason Chrome does not do playback anymore. Firefox works fine...
Any clues as to why?
raydude
Post by raydude » Sat Nov 17, 2018 5:14 pm
Okay. It's recording now...
But it's storing in the wrong place...
Damnit.
Where do I set the path information?
Post by bbunge » Sat Nov 17, 2018 5:53 pm
In the GUI: Options - Storage
raydude
Post by raydude » Sat Nov 17, 2018 6:01 pm
Thanks bbunge. I changed it there and it is still looking in the wrong location.
Perhaps I shouldn't have added a new storage, deleted the default and then renamed the newstorage as default?
raydude
Post by raydude » Sun Nov 18, 2018 9:28 pm
I fixed the location issue. /etc/conf.d/zmcustom.conf contained the actual directory locations. I updated them. That is a gentoo thing, I think.
Now I can't get zoneminder to use deep directory structure. It's looking for medium or shallow (I don't know how to tell the difference. It's looking for YYYY-MM-DD/ instead of yy/mm/dd.
I checked the zm database and verified that ZM_USE_DEEP_STORAGE is set to 1.
I'm so stuck...
